brianmichalk
I am running Eclipse Mars, and the Arduino V3 plugin. I can build a project for my Arduino.
Next, I installed TeensyDuino 1.28.
I created a new Arduino project, set the board to Teensy 3.2, and selected the default example sketch for Blink.
The Problems tab is showing two scanner discovery problems for arm-non-eabi-g++ and arm-non-eabi-gcc
Console output:
10:40:57 **** Incremental Build of configuration Release for project teensytest ****
make all
Building file: ../.ino.cpp
Starting C++ compile
/bin/sh: 1: /hardware/tools/arm/bin/arm-none-eabi-g++: not found
"/hardware/tools/arm/bin/arm-none-eabi-g++" -c -Os -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=128 -DARDUINO=10606 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I"/home/michalk/eclipse-mars/arduino-1.6.5-r5/hardware/teensy/avr/cores/teensy3" -MMD -MP -MF".ino.cpp.d" -MT".ino.cpp.o" -D__IN_ECLIPSE__=1 -x c++ "../.ino.cpp" -o ".ino.cpp.o" -Wall
make: *** [.ino.cpp.o] Error 127
10:40:57 Build Finished (took 78ms)
It's not clear to me where I would set the path to the compiler. I've set my Eclipse environment path to:
/bin:/usr/bin:${eclipse_home}/arduino-1.6.5-r5
I've tried other forms of variables, and can't seem to get this to work.
Console output:
make all
