LC Doesn't Repond to Reset Button
I'm doing some work with an LC using both i2c channels. Sometimes the LC will hang and pressing the reset button won't bring it back so I have to pull and replace the power lead.
This is not a huge problem but I'm curious as to why this might be happening.
Also, this morning I noticed that when I attach a logic probe to the LC and run my program that uses i2c to pass data between the Teensy and a Pi after a few seconds the Teensy hangs and won't come back. The probes are properly grounded and the behavior stops when I remove them. Any ideas why?
Thanks,
Eric
Senior Member+
Actually there is no reset button. The button is actually a "Program" button, and when pressed puts the teensy into program mode waiting for a new program to download.
As for why hang, not sure... What type of logic probe,... Also helps to have more information, program code...
Originally Posted by
KurtE
Well - that's useful.
My hang problem with the probe went away. The probe is a Saleae Logic 8. I've noticed that the Teensy is sensitive to anything that might degrade the i2c signal. The probe has about an 8" lead - I've got another 8" from there to the breadboard. Then there is are 4" leads between the LC and the Pi.
I'm using the Pi to power the LC and a few sensors. I wonder if voltage might contribute to things.
My code is nothing spectacular on the Teensy side. I'm using Wire and Wire1. This is the bulk of it:
// In setup
// register events
Wire1.onReceive(receiveEvent);
Wire1.onRequest(requestEvent);
// In body
// handle Rx Event (incoming I2C request/data)
void receiveEvent(size_t len)
if (Wire1.available())
addr = Wire1.readByte();
// handle Tx Event (outgoing I2C data)
void requestEvent(void)
Wire1.write(mem[memPtr][addr]); // fill Tx buffer (from addr location to end of mem)
I ran into this problem when I powered the teensy from an isolated power supply, it was very sensitive to touching anything connected to it. When I inserted a USB cable (for data connection, VUSB cut), the problem vanished, I guess because the system now had a proper GND connection to the rest of the world through the USB GND.
Ben
Thanks for the tip - I'll take a look at that.
- You may not post replies
- You may not edit your posts
Forum Rules
