Results 1 to 1 of 1
Thread: Audio Workshop Part_3_03_TFT_Display Code Compatibility
    Does the Part_3_03_TFT_Display code listed in the Audio Workshop pdf work with the DISPLAY_ILI9341_TOUCH 2.8 inch color display from PJRC? The workshop uses a 9 pin version of the ILI9341_T3 display where the TOUCH has 14 pins. Not sure how to hook it up using the breadboard connections pictured on page 31. Problem is I can't find a schematic posted for the DISPLAY_ILI9341_TOUCH on any documentation at PJRC or Adafruit websites. If the code or pin assignment is different, can you tell me what to change? Thanks much.
