ChrisRowland
I've a suggestion when fitting the RTC crystal on the Teensy 3.2, fit the crystal to the top of the board and solder it from the bottom.
I tried doing it the other way and a slight slip of the soldering iron deposited solder on some of the pins of the MK20 IC shorting them out. If you solder on the bottom of the board, with the crystal on top, there's much less to disturb.
Not sure if I can recover it, the pins involved are 22 to 27 which involve the MKL device and the USB. Blink runs, the USB connection seems to be partially made but the device isn't recognised as a Teensy. Not sure if my very limited surface mount rework skills are up to this.
I'm not blaming anyone, other than myself, just hoping this will help others avoiding getting into this state.
Chris
Chris
