Teensy ++ 2 EEPROM Programmer - a good idea ?
pixelk
I need to flash some Atmel 29C256 Parallel EEPROM, And thought that a Teensy ++ 2.0 I have laying around would be perfect for the job (and that the commercial programmer are way to expensive for my 4 chips need), but after some searching everybody seems to use some multiplexers and less pins to program them. Is my idea of simply using the many pins of the ++ to directly connect to the EEPROM a stupid one ?
I don't think it would be too hard to do, but as it seems nobody does it that way, I just wanted to know if I'm missing anything obvious before investing time in it.
That's how I'd do it, if I was building such a thing from scratch.
But whether I'd build it from scratch would depend on how well documented existing designs are...
Thank you, I only could find some distantly related projects and the datasheet of the eeprom.
I'll try to do it and document it as well as I can.
I'll stop trying when it works or I feel that my time is more valuable than the first Chinese programmer I can find :)
I changed the eprom type for a 29F020, a bit bigger and easier to program. appart from the rat's nest of wire, the hardware part should be straightforward.
Soldering done.
But before firing it up, I'll test everything for continuity and probably make myself a test rig (essentially a fake DIP40 with leds on every pins).
I've been able to perfectly read an W29C020C-90B EEPROM chip from an Abit KA7-100 Motherboard made in the year 2000 (I kept the EEPROM "just in case") and I was able to download the BIOS file from this exact version and they MATCH !
\o/
If by any chance it would be usefull to anybody, here is the source for that : Teensy2EEPROM_0_1_4_A_74BEE132.zip ( 1,5 ko ).
