Finally_Joe
Howdy, again.
Forgive me if this answer exists on the forum, I believe I saw it once, but now I cannot find it...
So I've got the MKL26 micro on a separate board with all the necessary Teensyduino programming pins broken out to a connector and I program the MKL26 with a Teensy-LC board minus the MKL26. This all works really well.
The first one that I programmed wouldn't run the code, after programming and disconnecting from the Teensy-LC remains, until I pulled the RESET_B pin on the MKL26 high. So I've just been soldering a jumper to pull that RESET_B pin high after I program the MKL26.
Today, I programmed another MKL26 the same way as before, and after I disconnected the Teensy-LC remains but before I pulled the RESET_B pin high, the program is running fine... with the RESET_B pin left floating.
Does anyone know which way ought to be the correct way?
Thank you.
-Joe
Thank you.
-Joe
