I do not know why that error occurred.
What's the problem?
Below is the error message.
What's the problem?
Arduino:1.6.7 (Mac OS X), TD: 1.28, Board:"Teensy 3.2 / 3.1, Serial, 96 MHz optimized (overclock), US English"
In file included from /var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/arduino_3af926170f20c7c65a136cb2f2d69967/ShiftPWM_RGB_Example.ino:35:0:
/Users/Jymno/Downloads/Arduino 3.app/Contents/Java/hardware/teensy/avr/libraries/ShiftPWM/ShiftPWM.h: In function 'void ShiftPWM_handleInterrupt()':
/Users/Jymno/Downloads/Arduino 3.app/Contents/Java/hardware/teensy/avr/libraries/ShiftPWM/ShiftPWM.h:125:27: warning: unused variable 'latchPort' [-Wunused-variable]
volatile uint8_t * const latchPort = port_to_output_PGM_ct[digital_pin_to_port_PGM_ct[ShiftPWM_latchPin]];
/var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/build3af926170f20c7c65a136cb2f2d69967.tmp/sketch/ShiftPWM_RGB_Example.ino.cpp.o: In function `setup':
/var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/arduino_3af926170f20c7c65a136cb2f2d69967/ShiftPWM_RGB_Example.ino:51: undefined reference to `CShiftPWM::SetAmountOfRegisters(unsigned char)'
/var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/arduino_3af926170f20c7c65a136cb2f2d69967/ShiftPWM_RGB_Example.ino:55: undefined reference to `CShiftPWM::SetPinGrouping(int)'
/var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/arduino_3af926170f20c7c65a136cb2f2d69967/ShiftPWM_RGB_Example.ino:57: undefined reference to `CShiftPWM::Start(int, unsigned char)'
/var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/build3af926170f20c7c65a136cb2f2d69967.tmp/sketch/ShiftPWM_RGB_Example.ino.cpp.o: In function `rgbLedRainbow(int, int, int, int)':
/var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/arduino_3af926170f20c7c65a136cb2f2d69967/ShiftPWM_RGB_Example.ino:175: undefined reference to `CShiftPWM::SetAll(unsigned char)'
/var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/arduino_3af926170f20c7c65a136cb2f2d69967/ShiftPWM_RGB_Example.ino:180: undefined reference to `CShiftPWM::SetHSV(int, unsigned int, unsigned int, unsigned int, int)'
/var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/build3af926170f20c7c65a136cb2f2d69967.tmp/sketch/ShiftPWM_RGB_Example.ino.cpp.o: In function `loop':
/var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/arduino_3af926170f20c7c65a136cb2f2d69967/ShiftPWM_RGB_Example.ino:65: undefined reference to `CShiftPWM::SetAll(unsigned char)'
/var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/arduino_3af926170f20c7c65a136cb2f2d69967/ShiftPWM_RGB_Example.ino:68: undefined reference to `CShiftPWM::PrintInterruptLoad()'
/var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/arduino_3af926170f20c7c65a136cb2f2d69967/ShiftPWM_RGB_Example.ino:71: undefined reference to `CShiftPWM::OneByOneFast()'
/var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/arduino_3af926170f20c7c65a136cb2f2d69967/ShiftPWM_RGB_Example.ino:75: undefined reference to `CShiftPWM::SetAll(unsigned char)'
/var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/arduino_3af926170f20c7c65a136cb2f2d69967/ShiftPWM_RGB_Example.ino:80: undefined reference to `CShiftPWM::SetAll(unsigned char)'
/var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/arduino_3af926170f20c7c65a136cb2f2d69967/ShiftPWM_RGB_Example.ino:87: undefined reference to `CShiftPWM::SetAll(unsigned char)'
/var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/arduino_3af926170f20c7c65a136cb2f2d69967/ShiftPWM_RGB_Example.ino:89: undefined reference to `CShiftPWM::SetOne(int, unsigned char)'
/var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/arduino_3af926170f20c7c65a136cb2f2d69967/ShiftPWM_RGB_Example.ino:90: undefined reference to `CShiftPWM::SetOne(int, unsigned char)'
/var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/arduino_3af926170f20c7c65a136cb2f2d69967/ShiftPWM_RGB_Example.ino:97: undefined reference to `CShiftPWM::SetAllHSV(unsigned int, unsigned int, unsigned int)'
/var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/arduino_3af926170f20c7c65a136cb2f2d69967/ShiftPWM_RGB_Example.ino:106: undefined reference to `CShiftPWM::SetRGB(int, unsigned char, unsigned char, unsigned char, int)'
/var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/arduino_3af926170f20c7c65a136cb2f2d69967/ShiftPWM_RGB_Example.ino:109: undefined reference to `CShiftPWM::SetRGB(int, unsigned char, unsigned char, unsigned char, int)'
/var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/arduino_3af926170f20c7c65a136cb2f2d69967/ShiftPWM_RGB_Example.ino:112: undefined reference to `CShiftPWM::SetRGB(int, unsigned char, unsigned char, unsigned char, int)'
/var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/arduino_3af926170f20c7c65a136cb2f2d69967/ShiftPWM_RGB_Example.ino:115: undefined reference to `CShiftPWM::SetRGB(int, unsigned char, unsigned char, unsigned char, int)'
/var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/arduino_3af926170f20c7c65a136cb2f2d69967/ShiftPWM_RGB_Example.ino:118: undefined reference to `CShiftPWM::SetRGB(int, unsigned char, unsigned char, unsigned char, int)'
/var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/build3af926170f20c7c65a136cb2f2d69967.tmp/sketch/ShiftPWM_RGB_Example.ino.cpp.o:/var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/arduino_3af926170f20c7c65a136cb2f2d69967/ShiftPWM_RGB_Example.ino:121: more undefined references to `CShiftPWM::SetRGB(int, unsigned char, unsigned char, unsigned char, int)' follow
/var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/arduino_3af926170f20c7c65a136cb2f2d69967/ShiftPWM_RGB_Example.ino:130: undefined reference to `CShiftPWM::SetHSV(int, unsigned int, unsigned int, unsigned int, int)'
/var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/arduino_3af926170f20c7c65a136cb2f2d69967/ShiftPWM_RGB_Example.ino:156: undefined reference to `CShiftPWM::SetHSV(int, unsigned int, unsigned int, unsigned int, int)'
/var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/arduino_3af926170f20c7c65a136cb2f2d69967/ShiftPWM_RGB_Example.ino:159: undefined reference to `CShiftPWM::SetRGB(int, unsigned char, unsigned char, unsigned char, int)'
/var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/build3af926170f20c7c65a136cb2f2d69967.tmp/sketch/ShiftPWM_RGB_Example.ino.cpp.o: In function `__static_initialization_and_destruction_0':
/Users/Jymno/Downloads/Arduino 3.app/Contents/Java/hardware/teensy/avr/libraries/ShiftPWM/ShiftPWM.h:68: undefined reference to `CShiftPWM::CShiftPWM(int, bool, int, int, int)'
/var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/build3af926170f20c7c65a136cb2f2d69967.tmp/sketch/ShiftPWM_RGB_Example.ino.cpp.o: In function `_GLOBAL__sub_I_ShiftPWM':
/var/folders/jv/lpvjh58j1xn8g8fcv9fvz5dr0000gn/T/arduino_3af926170f20c7c65a136cb2f2d69967/ShiftPWM_RGB_Example.ino:185: undefined reference to `CShiftPWM::~CShiftPWM()'
collect2: error: ld returned 1 exit status
Error compiling for "Teensy 3.2 / 3.1"
