Results 1 to 17 of 17
Thread: Teensyduino 1.29 Beta #4 Available
    Administrator Paul's Avatar
    Oct 2012
    306
    Here is a fourth (and hopefully final) beta test for Teensyduino 1.29.
    EDIT: beta test link removed.
    Change since 1.29-beta3 are mostly K66 support...
    6,862
    Done and works Win_10 - No problems.
    Did get a warning on downloaded file:
    18,355
    Thanks. It really does help, try new betas quickly.
    I'm updating my Win10 install now. We just paid for that new code signing cert... hope Microsoft didn't change policies *again* so soon.
    18,355
    I tried downloading just now with IE. Can't reproduce the problem.
    Any ideas? Does Windows give you any more info if you right click on the installer and select Properties and the Digital Signatures tab?
    6,862
    False Alarm? Double Download confusion? Somehow EDGE corrupted or confused it.
    I just downloaded again with no issue. If you look at the text in my screen shot it notes TeensyInstall(1). I ended up with two parallel downloads and both were in my downloads. Both reported the same size, I deleted the (1) file and used the primary TeensyInstall.exe.
    Senior Member sumotoy's Avatar
    Venezia, Italia
    421
    installed and run fine here so far... Win 10/64
    Germany NRW
    4,540
    AudioInputUSB is missing - but there's an example "PassTroughUSB"
    @Paul, do you want to add output_PT8211, or is it too late ?
    18,355
    I just tried here. It compiles. A couple warnings, but compiles ok.
    Did you set Tools > USB Type to Audio?
    18,355
    Definitely too late for 1.29.
    But I have been putting some thought into this. Rather than grow the number of objects for many similar formats, perhaps the AudioOutputI2S constructor ought to have an optional parameter for other formats, like right & left justified.
    Long-term we're going to have a many more input and output objects, for various communication like ethernet streaming, bluetooth, etc.
    Germany NRW
    4,540
    oops.. no, of course not
    works. sorry
    Germany NRW
    4,540
    ..and without input, mclk..
    Ok, just disable the mclk (not needed), input, and remove the frame-sync-early.
    Venezia, Italia
    421
    In SPI library.cpp, function
    bool SPIClass::pinIsChipSelect(uint8_t pin1, uint8_t pin2)
    There's a debug serial that should be commented:
    Serial.printf("pinIsChipSelect %d %d %x %x\n\r", pin1, pin2, pin1_mask, pin2_mask);
    3,653
    Yes sorry, wil put in delta in morning
    3,653
    Pull request: https://github.com/PaulStoffregen/SPI/pull/14
    Sorry I missed that one.
    Jan 2016
    8
    still serial-problems with osx el capitan.
    https://forum.pjrc.com/threads/34196...hlight=capitan
    sometimes it works, sometimes it does not.
    18,355
    Quote Originally Posted by inx View Post
    I tried again to reproduce this problem, but couldn't. See my post on that thread with a screenshot.
    Oct 2012
    306
    Teensyduino 1.29 has been released.
    http://www.pjrc.com/teensy/td_download.html
