Resonance test results - Mouser crystals
So far, have had a quick look through 25 of the 50 crystals. They all appear similar in performance and within the 30 ppm spec. I have tested 4 pieces directly in the radio receiver (when synched with the Teensy sq wave) and they all worked with a little adjustment (4.7pF capacitor in parallel with crystal itself, and tweaking of the 60pF trimmer).
I also conducted some precise crystal resonance tests. These tests have provided some very interesting information - and thrown up some good questions. In the tests, I used an exact copy of the IC3 stage filter, and the input was 1.8 volts pk-pk from my Signal Generator (
http://www.ebay.co.uk/itm/MHS-5200A...tor-Source-Frequency-Meter-12S6-/351479922752). I calibrated the Sig Gen by setting its frequency such that the filter output had ZERO SCREEN DRIFT when displaying 6 full cycles on a scope against a GPS locked 10 KHz signal as the scope trigger. The Sig Gen displayed 60.00028 KHz, so that told me that the display offset was 0.00028 KHz (when the output was a true exact value of 60.00000 KHz).
Here are the results:
Remember that the breadboard has significant inherent capacitance between the 6 hole rows. The results in test A are with the crystal simply plugged in and without any attempt at providing a parallel loading capacitance (which the spec says should be 12.5 pF to expect resonance at precisely 60.0000 KHz). However, there will be some capacitance contribution from the breadboard.
The "Mid" true frequency value for test A of 60.00130 KHz indicates that the breadboard capacitance is somewhere between 0 and 12.5pF. The Mid frequency is a little on the high side, so the breadboard has not managed to provide enough additional parallel capacitance to pull it down to precisely 60.00000 KHz.
Test B shows what happened when I put a 12pF capacitor in parallel with the citizen crystal. Now you can see that peak resonance occured below 60 KHz at 59.99850 KHz. So the breadboard plus the 12pF has pulled the frequency down under the specified value.
Test C shows what happened when I put a 4.7pF capacitor in parallel. Now the Mid freq peak resonance is 59.99970 Khz. This is only 0.00030 KHz below the spec'd requirement, so I then used this back in the radio receiver (replacing my original crystal) as shown below:
And here is a corresponding scope display when used in the radio with Teensy synchronised to the sine wave down the twisted pair:
When comparing this to the picture in post #14, you can see that the amplitude of the radio output sine wave is slightly smaller. I did tweak the 60pF trimmer for maximum amplitude.
Another interesting point to note is the frequency value display in the top right corner of the scope picture. This shows "60.0004 kHz", which also tells me that the independant frequency counter inside the Rigol scope is offset by 0.0004 kHz too high.
Not only has this resonance test exercise calibrated my Sig Gen, it has also calibrated my scope's counter display too
!! This really shows the power of this MSF radio signal and the power of Teensy synchronised to it. If anyone can display the WWVB signal, then they can manually use the ZERO PHASE DRIFT principle to calibrate the Teensy output - even if the BPSK update of 2012 prevents automatic synchronisation.
If you have any other medium or long wave transmitter signal locally, which is synchronised to a GPS reference, then provided the "numbers" are favourable, you might be able to use that transmitter rather than WWVB.
In respect of the other questions that these results has thrown up, I'll make comment in a later post.
