Results 1 to 11 of 11
Thread: Teensy 3.1 / adafruit 1.77" tft
    May 2016
    9
    Hi all
    I got this TFT display 1.77" ADAFRUIT ROBOT LCD
    Webpage indicates ST7735 controller, so
    Using IDE 1.6.9 teensyduino 1.29 beta 1
    Loaded examples from TEENSYDUINO / ADAFRUIT for ST77356 (graphictest)
    NO JOY on display. SD CARD works on sketches that load .bmp files from sdcard but just lines blocks flickering on display
    thus I believe the SPI interface works but commands to display is suspect
    I got hold of spec-sheet for the display from chinese company. They specify ILI9163 controller
    My question..... Is the ILI9163 compatible to the ST7735?
    I also tried the TFT9163 examples but they report it cant be compiled for teensy 3.x ?????
    Please help. Thanx in advance
    May 2016
    9
    Photo of the display
    11,185
    I don't have the display, so probably can not help much.
    But it would help if included some additional information, like which pins of the Teensy go to which pins of your display. Are you using the Adafruit_ST7735 library that can be downloaded as part of Teensyduino?
    If you are using the Teensyduino version, if you look at the graphictest.ino file you will see:
    // This Teensy3 native optimized version requires specific pins
    #define sclk 13  // SCLK can also use pin 14
    #define mosi 11  // MOSI can also use pin 7
    #define cs   10  // CS & DC can use pins 2, 6, 9, 10, 15, 20, 21, 22, 23
    #define dc   9   //  but certain pairs must NOT be used: 2+10, 6+9, 20+23, 21+22
    #define rst  8   // RST can use any pin
    #define sdcs 4   // CS for SD card, can use any pin
    16,544
    You don't link to the device and I don't find it at Adafruit - don't know the pixel count? Is it 128x128?
    sumotoy is updating for the 9163C controller that works very fast and well on my 1.44" - yours is 1.77" - not sure of resolution. Even this display has 3 known/supported variants.
    May 2016
    9
    Thanx for responses
    - The device is 126x160 pixels. It also has a GREEN TAB film on the screen. On the back it indicates ARDUINO ROBOT LCD.
    - Our local supplier's website indicates a ST7735 with links to ADAFRUIT. {www.robotics.org.za/index.php?route=product/product&path=64&product_id=138}
    - I used the pin allocation as per ST7735 examples. The SPI works to the SD CARD
    - Yes I use the library from TEENSYDUINO
    27,129
    Can you post a photo showing how you've actually connected the wires?
    This display really should work with the Adafruit_ST7735 library supplied by Teensyduino (which is highly optimized... much faster than Adafruit's original).
    May 2016
    9
    Thanx all.
    I got the display working with sumotoy's IL9163 library.
    THUS the supplier was at fault to specify ST7735 controller.
    Thanx all for inputs
    Jul 2016
    3
    Hello.
    I had a question. In the pin #define statements there is a define for mosi but no define for miso. How come ? What if someone wants to read data from the sd card ? In the original adafruit libraries both mosi and miso were defined.
    I am talking about the examples for the teensy optimized codes
    Jul 2016
    3
    I know this is a noob question but I was just curious as I want to do a mini project of connecting the teensy to a ov7675 camera and this display shield and capture/display photos
    Jul 2013
    Colorado
    87
    I can't really comment on the specific example you are asking about since you did not include the whole program or a link (see Forum Rule) perhaps it is an example with no read need?
    SPI on Teensy LC and T3 works with pins identified on the cards there are library calls to set both MOSI/MISO the T-LC supports two SPI busses
    The card identifies the primary and alternate pins allowed.
    Does this help answer your Question?
    Jul 2016
    3
    Sorry for not being precise. I was referring to this example:
    https://github.com/PaulStoffregen/Ad...itftbitmap.ino
    I have a teensy 3.2 . There definitely is a need for read ( reading data from the sd cad). Could it be that when you define just the one mosi pin the correponding miso pin is set automatically by the library ?
