Heya,
I am trying to wrangle getting a http://www.seeedstudio.com/wiki/Grove_-_Tempture&Humidity_Sensor_(High-Accuracy_&Mini)_v1.0 sensor working with a teensy 3.2 over the i2c bus. I replaced all the references from Wire.h to i2c_t3.h and the sample code compiled without complaints. But what I run the sample code nothing is printing to the serial monitor (and yes, my usb serial stuff is working fine with other code, etc).
I have read through some threads regarding some of the bewildering nuances of porting code over from AVR to teensy stuff and it's pretty much over my level of C code sophistication. The TH02 code seems fairly compact but I can't see clearly what else I might change in the libraries or sample code to make the sensor talk to the teensy properly. Anybody have any ideas?
Any help would be appreciated.
Thanks.
Thanks.
