Error on build for ARM Teensy 3.2 with U8G2 library
Hi folks !
I have started to test the new U8G2 library developed by Oliver Kraus but it seems that his library is not compatible with the compiler for ARM Teensy boards. I'm not an expert, so it's a bit hard for me to find where the problem can be.
My board is a Teensy 3.2, but a I tried to make a build on Teensy 3.0 or LC and the problem remain the same. There is no issue if I'm building a version for Arduino boards... looks like there is something incompatible with ARM in this library...
If Paul or someone else is the forum have an idea, we can then help Oliver to make his library also compatible with Teensy board
Here the log of the build - please note that I have shorten it a bit to fit in the 80000 characters allowed for a post
Thank you and have a great day !
Christophe
Hi folks !
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware "/Applications/Arduino.app/Contents/Java/hardware" -tools "/Applications/Arduino.app/Contents/Java/tools-builder" -tools "/Applications/Arduino.app/Contents/Java/hardware/tools/avr" -built-in-libraries "/Applications/Arduino.app/Contents/Java/libraries" -libraries "/Users/christophepersoz/Developer/_Arduino/libraries" -fqbn=teensy:avr:teensy31:usb=serial,speed=96opt,keys=en-us -ide-version=10607 -build-path "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp" -warnings=none -verbose "/Users/christophepersoz/Library/Mobile Documents/com~apple~CloudDocs/Developer/_Arduino/Projets/Tests_U8G2/FPS_FrameBuffer/FPS_FrameBuffer.ino"
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware "/Applications/Arduino.app/Contents/Java/hardware" -tools "/Applications/Arduino.app/Contents/Java/tools-builder" -tools "/Applications/Arduino.app/Contents/Java/hardware/tools/avr" -built-in-libraries "/Applications/Arduino.app/Contents/Java/libraries" -libraries "/Users/christophepersoz/Developer/_Arduino/libraries" -fqbn=teensy:avr:teensy31:usb=serial,speed=96opt,keys=en-us -ide-version=10607 -build-path "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp" -warnings=none -verbose "/Users/christophepersoz/Library/Mobile Documents/com~apple~CloudDocs/Developer/_Arduino/Projets/Tests_U8G2/FPS_FrameBuffer/FPS_FrameBuffer.ino"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/sketch/FPS_FrameBuffer.ino.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/sketch/FPS_FrameBuffer.ino.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/sketch/FPS_FrameBuffer.ino.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/U8x8lib.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire"
"/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8g2_font.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8g2_fonts.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8g2_hvline.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8g2_input_value.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8g2_intersection.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8g2_line.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8g2_ll_hvline.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8g2_message.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8g2_polygon.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8g2_selection_list.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8g2_setup.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8x8_8x8.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8x8_byte.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8x8_cad.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8x8_d_ld7032_60x32.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8x8_d_ls013b7dh03.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8x8_d_ssd1306_128x32.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8x8_d_ssd1306_128x64_noname.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8x8_d_ssd1322.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8x8_d_st7565.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8x8_d_st7920.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8x8_d_t6963.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8x8_d_uc1701_dogs102.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8x8_debounce.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8x8_display.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8x8_fonts.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8x8_gpio.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8x8_input_value.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8x8_message.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8x8_selection_list.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8x8_setup.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8x8_string.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8x8_u16toa.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/clib/u8x8_u8toa.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI/SPI.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/sketch/FPS_FrameBuffer.ino.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire/Wire.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire/utility/twi.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/sketch/FPS_FrameBuffer.ino.cpp" -o "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/preproc/ctags_target_for_gcc_minus_e.cpp"
"/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino5/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/preproc/ctags_target_for_gcc_minus_e.cpp"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/sketch/FPS_FrameBuffer.ino.cpp" -o "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/sketch/FPS_FrameBuffer.ino.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10607 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino/src/U8x8lib.cpp" -o "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/U8x8lib.cpp.o"
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_bitmap.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_box.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_buffer.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_circle.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_cleardisplay.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_d_memory.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_d_setup.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_font.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_fonts.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_hvline.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_input_value.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_intersection.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_line.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_ll_hvline.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_message.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_polygon.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_selection_list.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_setup.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_8x8.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_byte.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_cad.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_d_ld7032_60x32.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_d_ls013b7dh03.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_d_ssd1306_128x32.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_d_ssd1306_128x64_noname.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_d_ssd1322.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_d_st7565.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_d_st7920.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_d_t6963.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_d_uc1701_dogs102.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_debounce.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_display.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_fonts.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_gpio.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_input_value.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_message.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_selection_list.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_setup.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_string.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_u16toa.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_u8toa.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/SPI/SPI.cpp.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/Wire/Wire.cpp.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/Wire/utility/twi.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/memcpy-armv7m.S.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/memset.S.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/analog.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/eeprom.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/keylayouts.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/math_helper.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/mk20dx128.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/nonstd.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/pins_teensy.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/ser_print.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/serial1.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/serial2.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/serial3.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/serial4.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/serial5.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/touch.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/usb_desc.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/usb_dev.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/usb_joystick.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/usb_keyboard.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/usb_mem.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/usb_midi.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/usb_mouse.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/usb_mtp.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/usb_rawhid.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/usb_seremu.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/usb_serial.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/usb_touch.c.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/AudioStream.cpp.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/DMAChannel.cpp.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/HardwareSerial1.cpp.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/HardwareSerial2.cpp.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/HardwareSerial3.cpp.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/HardwareSerial4.cpp.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/HardwareSerial5.cpp.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/IPAddress.cpp.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/IntervalTimer.cpp.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/Print.cpp.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/Stream.cpp.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/Tone.cpp.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/WMath.cpp.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/WString.cpp.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/avr_emulation.cpp.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/main.cpp.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/new.cpp.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/usb_audio.cpp.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/usb_flightsim.cpp.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/usb_inst.cpp.o
Using previously compiled file: /var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/yield.cpp.o
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/memcpy-armv7m.S.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/memset.S.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/analog.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/eeprom.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/keylayouts.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/math_helper.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/mk20dx128.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/nonstd.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/pins_teensy.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/ser_print.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/serial1.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/serial2.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/serial3.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/serial4.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/serial5.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/touch.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/usb_desc.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/usb_dev.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/usb_joystick.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/usb_keyboard.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/usb_mem.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/usb_midi.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/usb_mouse.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/usb_mtp.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/usb_rawhid.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/usb_seremu.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/usb_serial.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/usb_touch.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/AudioStream.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/DMAChannel.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/HardwareSerial1.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/HardwareSerial2.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/HardwareSerial3.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/HardwareSerial4.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/HardwareSerial5.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/IPAddress.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/IntervalTimer.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/Print.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/Stream.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/Tone.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/WMath.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/WString.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/avr_emulation.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/main.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/new.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/usb_audio.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/usb_flightsim.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/usb_inst.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/yield.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -O -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1468831828 "-T/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/mk20dx256.ld" -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -o "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/FPS_FrameBuffer.ino.elf" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/sketch/FPS_FrameBuffer.ino.cpp.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/U8x8lib.cpp.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_bitmap.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_box.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_buffer.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_circle.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_cleardisplay.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_d_memory.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_d_setup.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_font.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_fonts.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_hvline.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_input_value.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_intersection.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_line.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_ll_hvline.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_message.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_polygon.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_selection_list.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8g2_setup.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_8x8.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_byte.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_cad.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_d_ld7032_60x32.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_d_ls013b7dh03.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_d_ssd1306_128x32.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_d_ssd1306_128x64_noname.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_d_ssd1322.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_d_st7565.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_d_st7920.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_d_t6963.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_d_uc1701_dogs102.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_debounce.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_display.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_fonts.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_gpio.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_input_value.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_message.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_selection_list.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_setup.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_string.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_u16toa.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/U8g2_Arduino/clib/u8x8_u8toa.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/SPI/SPI.cpp.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/Wire/Wire.cpp.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/libraries/Wire/utility/twi.c.o" "/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp/core/core.a" "-L/var/folders/93/95zp52wn3dq81d0dgrtmj_b80000gn/T/build8c5df198fdd0faaaf006ad4bcf1c1d89.tmp" -larm_cortexM4l_math -lm
[B]/Applications/Arduino.app/Contents/Java/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/4.8.4/../../../../arm-none-eabi/lib/armv7e-m/libc.a(lib_a-signalr.o): In function `_kill_r':
signalr.c:(.text._kill_r+0xe): undefined reference to `_kill'
/Applications/Arduino.app/Contents/Java/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/4.8.4/../../../../arm-none-eabi/lib/armv7e-m/libc.a(lib_a-signalr.o): In function `_getpid_r':
signalr.c:(.text._getpid_r+0x0): undefined reference to `_getpid'
collect2: error: ld returned 1 exit status[/B]
Using library U8g2_Arduino at version 2.1.1 in folder: /Users/christophepersoz/Developer/_Arduino/libraries/U8g2_Arduino
Using library SPI at version 1.0 in folder: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI
Using library Wire at version 1.0 in folder: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire
[B]Error compiling for "Teensy 3.2 / 3.1"[/B]
Thank you and have a great day !
Christophe
