oddson
Has Paul discussed a plan for usbMIDI to be updated to match the MIDI library on things like getType() and sysex handling (beyond the TODOs in the source code)?
It seems to me the current situation is making it difficult to use usbMIDI calls to handle things like software MIDI-thru/merge, MIDI over Bluetooth and anything where you need to move data between them or process all non-sysex in the same manner regardless of type.
While one can work around these I think it potentially detracts from Teensy's advantages for MIDI and even Audio projects if there's no simple solution to simple MIDI issues when dealing with both libraries.
