Hi. I am trying to use std::map, but am getting errors.
I am using a Teensy 3.1. I have tried both the Arduino software and Make. I am running ArchLinux.
MNWE:
Error:
Is std::map not usable on the Teensy?
MNWE:
#include "stdlib.h"
#include "map"
std::map<int, int> foobar;
foobar[1] = 5;
Error:
/tmp/build684d5482831b8cc901740cd5055404f4.tmp/sketch/map_test.ino.cpp.o: In function `std::_Rb_tree_iterator<std::pair<int const, int> >::operator--()':
/usr/share/arduino/hardware/tools/arm/arm-none-eabi/include/c++/4.8.4/bits/stl_tree.h:204: undefined reference to `std::_Rb_tree_decrement(std::_Rb_tree_node_base*)'
/tmp/build684d5482831b8cc901740cd5055404f4.tmp/sketch/map_test.ino.cpp.o: In function `std::_Rb_tree_iterator<std::pair<int const, int> >::operator++()':
/usr/share/arduino/hardware/tools/arm/arm-none-eabi/include/c++/4.8.4/bits/stl_tree.h:189: undefined reference to `std::_Rb_tree_increment(std::_Rb_tree_node_base*)'
/tmp/build684d5482831b8cc901740cd5055404f4.tmp/sketch/map_test.ino.cpp.o: In function `std::_Rb_tree<int, std::pair<int const, int>, std::_Select1st<std::pair<int const, int> >, std::less<int>, std::allocator<std::pair<int const, int> > >::_M_insert_node(std::_Rb_tree_node_base*, std::_Rb_tree_node_base*, std::_Rb_tree_node<std::pair<int const, int> >*)':
/usr/share/arduino/hardware/tools/arm/arm-none-eabi/include/c++/4.8.4/bits/stl_tree.h:1575: undefined reference to `std::_Rb_tree_insert_and_rebalance(bool, std::_Rb_tree_node_base*, std::_Rb_tree_node_base*, std::_Rb_tree_node_base&)'
collect2: error: ld returned 1 exit status
