PaulStoffregen
Looks like Arduino.cc just released IDE version 1.6.10.
I'm downloading the code now. Will update Teensyduino later today...
They could have used gcc -H to output the include file names as the compiler does the normal compile, but then you have to use a tool to separate the -H output from any warnings.FWIW, they were going to use another (likely buggy) tool called "coan" together with ctags. I and others talked them into instead using "gcc -E", which is unfortunately slower, but it is absolutely guaranteed to give the same preprocessing as gcc run in normal compile mode. I shudder to think what a mess 1.6.5 could have been if they'd used two different preprocessors to discover required library headers.
Uploading to board 'Shore Station' (Teensy 3.2)
Triggering board reboot
Firmware: LazarusShoreStationStrm23.ino.hex
Flash usage: 22 kiB (8.3%)
Uploading...
Sending reset command
An error occurred while uploading the sketch
Sketch uses 21,792 bytes (8%) of program storage space. Maximum is 262,144 bytes.
Global variables use 7,772 bytes (11%) of dynamic memory, leaving 57,764 bytes for local variables. Maximum is 65,536 bytes.
C:\Users\Root2\Downloads\Arduino\arduino-1.6.9-windows\arduino-1.6.9\hardware\teensy/../tools/teensy_post_compile -test -file=LazarusShoreStationStrm23.ino -path=C:\Users\Root2\AppData\Local\Temp\build35d5590c9e21101cfd0e702cb729720f.tmp -tools=C:\Users\Root2\Downloads\Arduino\arduino-1.6.9-windows\arduino-1.6.9\hardware\teensy/../tools -board=TEENSY31 -reboot
Teensy did not respond to a USB-based request to automatically reboot.
