Here is the code I am trying to use the Audio library to sample the adc with 44100 KHz. The read value did not look right.
// Record sound as raw data to a SD card, and play it back.
// Requires the audio shield:
http://www.pjrc.com/store/teensy3_audio.html
// Three pushbuttons need to be connected:
// Record Button: pin 0 to GND
// Stop Button: pin 1 to GND
// Play Button: pin 2 to GND
#include <Bounce.h>
AudioInputAnalog adc1(A0); //xy=145,295
AudioRecordQueue queue1; //xy=339,289
AudioConnection patchCord1(adc1, queue1);
// which input on the audio shield will be used?
// Remember which mode we're doing
int mode = 0; // 0=stopped, 1=recording, 2=playing
// The file where data is recorded
File frec;
Serial.println("Begin setup");
AudioMemory(60);
// First, read the buttons
if (mode == 0) startRecording();
continueRecording();
void startRecording() {
Serial.println("startRecording");
queue1.begin();
mode = 1;
void continueRecording() {
if (queue1.available() >= 2) {
byte buffer[1024];
// into a 512 byte buffer. The Arduino SD library
// writes are used.
queue1.freeBuffer();
memcpy(buffer, queue1.readBuffer(), 1024);
for(int i=0; i+2<1024;i=i+2){
unsigned int word = buffer
* 256 + buffer[i+1];
Serial.println(word);
// queue1.freeBuffer();
// memcpy(buffer+256, queue1.readBuffer(), 256);
// Uncomment these lines to see how long SD writes
// are taking. A pair of audio blocks arrives every
// 5802 microseconds, so hopefully most of the writes
// take well under 5802 us. Some will take more, as
// the SD library also must write to the FAT tables
// and the SD card controller manages media erase and
// wear leveling. The queue1 object can buffer
// approximately 301700 us of audio, to allow time
// for occasional high SD card latency, as long as
// the average write time is under 5802 us.
//Serial.print("SD write, us=");
//Serial.println(usec);
void stopRecording() {
Serial.println("stopRecording");
queue1.end();
if (mode == 1) {
frec.write((byte*)queue1.readBuffer(), 256);
frec.close();
mode = 0;
