Page 1 of 2 1 2 LastLast
Results 1 to 25 of 40
Thread: Teensyduino 1.30 Beta #2 Available
    Administrator Paul's Avatar
    Oct 2012
    294
    Here is a second beta test for Teensyduino 1.30.
    Arduino 1.6.10 has issues with some AVR-based boards (not Teensy). The Arduino devs are expected to release version 1.6.11 soon. I indent to hold off finalizing Teensyduino 1.30 until they've published 1.6.11 and we can test against 1.6.11 for at least a few days. Teensyduino 1.30 is likely to drop support for Arduino 1.6.10 after 1.6.11 is released.
    Edit: old beta test linkes removed. Full non-beta release is here:
    http://www.pjrc.com/teensy/td_download.html
    Changes since Teensyduino 1.30-beta1:
    • Fix for Teensy-LC (broken by recent K66 updates)
    • More K66 updates
    • Libraries updated: Audio, ADC, i2c_t3, IRremote
    3,534
    For the fun of it I tried installing Arduino 1.6.10 on an Odroid C2 which I installed a fresh copy of Ubuntu 16.04 (ARM 64 bit), to see if the 32 bit arm version would run on it, as I was earlier able to get the daily Arduino to run on the board, but I had played around a lot so was not sure what was needed...
    The problem is their ARM version is setup to run 32 bit java and other stuff, so it needs the 32 bit versions of the libraries it uses...
    I was able to get the basic Arduino to run by adding: sudo apt-get install libxtst6:armhf
    Next up Teensyduino 1.30 beta 2... I downloaded it and it would not run. Was able to get it to run by
    adding: sudo apt-get install libxft2:armhf
    Started up Arduino, loaded blink, plugged T3.2 into C2 and clicked upload. The program compiled, but the Teensy loader failed to load. Tried in command line and the reboot also failed to load. Fixed by
    adding: sudo apt-get install libusb-0.1-4:armh
    Still failed until I added the udev rules. But now my Teensy is blinking
    Note: it sometimes fails to program and I need to hit program button...
    Oct 2015
    14
    Audio.h still needs
    #include "synth_simple_drum.h"
    to make AudioSynthSimpleDrum work, and keywords.txt needs
    AudioSynthSimpleDrum	KEYWORD2
    (plus maybe some methods of AudioSynthSimpleDrum)
    Jun 2016
    Fremont, CA
    2
    Won't let me install this.. here's what I get when I click the ? button:
    Checking Arduino 1.6.10:
    version: "Contents/Java/lib/version.txt" file missing
    Does not match Arduino 1.6.10
    17,596
    Every copy of Arduino is supposed to have that version.txt file. Perhaps your copy got corrupted or damaged somehow? Maybe try downloading a fresh copy from Arduino.cc?
    Also, please be aware Arduino 1.6.10 is going to be replaced with 1.6.11 sometime next week. Teensyduino will drop support for 1.6.10 when that happens. Unless you have an urgent need, might be simplest to just wait to upgrade.
    Jun 2016
    Fremont, CA
    2
    Hmm it was a fresh download.. perhaps I'll just wait. Thanks!
    Apr 2013
    106
    I rewrite the RTC-Libray for the Arduino DUE and added it to the library and add it to the Library-Manager from the IDE, I modified your TimeArduinoDue.ino, Paul can you add it to your time library?
     * TimeArduinoDue.pde
     * example code illustrating Time library with Real Time Clock.
     * This example requires Markus Lange's Arduino Due RTC Library
     * https://github.com/MarkusLange/RTCDue
    #include <TimeLib.h>
    #include <RTCDue.h>
    // Select the Slowclock source
    //RTCDue rtc(RC);
    RTCDue rtc(XTAL);
    void setup()  {
      rtc.begin();
      if (rtc.isDateAlreadySet() == 0) {
        // Unfortunately, the Arduino Due hardware does not seem to
        // be designed to maintain the RTC clock state when the
        // board resets.  Markus described it thusly: "Uhh the Due
        // does reset with the NRSTB pin.  This resets the full chip
        // with all backup regions including RTC, RTT and SC.  Only
        // if the reset is done with the NRST pin will these regions
        // stay with their old values."
        rtc.setTime(__TIME__);
        rtc.setDate(__DATE__);
        // However, this might work on other unofficial SAM3X boards
        // with different reset circuitry than Arduino Due?
      setSyncProvider(getArduinoDueTime);
      if(timeStatus()!= timeSet)
         Serial.println("Unable to sync with the RTC");
         Serial.println("RTC has set the system time");
    time_t getArduinoDueTime()
      return rtc.unixtime();
       digitalClockDisplay();
    void digitalClockDisplay(){
      // digital clock display of the time
      Serial.print(hour());
      printDigits(minute());
      printDigits(second());
      Serial.print(" ");
      Serial.print(day());
      Serial.print(" ");
      Serial.print(month());
      Serial.print(" ");
      Serial.print(year());
    void printDigits(int digits){
      // utility function for digital clock display: prints preceding colon and leading 0
      Serial.print(":");
      if(digits < 10)
        Serial.print('0');
      Serial.print(digits);
    Hope you like it.
    Attached Files Attached Files
    Aug 2016
    2
    Ok so I bought a teensy, to use as midi control for an analog synth. Installed Teensyduino in my Arduino 1.6.10 IDE. Managed to upload one sketch using serial. But now, when put into program mode by pushing the button, I can't upload another sketch.
    Using Arduino + Teensyduino on a mac I get the following error:
    "Teensy did not respond to a USB-based request to automatically reboot.
    Please press the PROGRAM MODE BUTTON on your Teensy to upload your sketch."
    I already tried the following:
    - Unplugging the teensy, rebooting, plugging in the teensy, press program mode button, start up IDE. -> No success.
    - Repeating the same, but with a different USB port on the same system. -> No success.
    - Tried it on a windows machine. Did not work. -> No success
    - Tried it on another USB port, on the windows machine. -> no success.
    I use the stable build of the arduino IDE. The latest Mac OS X (10.11.6), the latest Windows 10 updates.
    17,596
    Quote Originally Posted by dikkedimi View Post
    I'm confused. Is this a mac or windows computer?
    Do not use a virtual machine. The USB emulation in virtual machines is often problematic for Teensy's quick rebooting, where it disconnects and reconnects as another device.
    Also, please understand Teensy Loader always uses HID protocol for uploading, not serial. More details here:
    http://www.pjrc.com/teensy/troubleshoot.html
    Aug 2016
    2
    Turns out my issue was due to a charging only cable. N00b oversight. Now it works like a charm! my complements for integrating it into the arduino IDE
    now I can get going with this again http://www.marc-nostromo.com/midi-co...comment-109498
    Germany NRW
    4,438
    Paul, is it possible to include the mmCau library ?
    http://www.nxp.com/products/microcon...sign_Tools_Tab
    It's a precompiled *.a (the assembler-source is included in the download) and a header-file.
    1,743
    Possible issue with teensy_reboot:
    Observation:
    programs compiled for Serial-Midi break Arduino reprogram feature, requiring button press.
    System PC win10, A1.6.9, TD 1.29
    test procedure (using Arduino IDE):
    download blink.hex compiled with Serial.
         download succeeds, will generate, say com19
    download blink.hex compiled with Serial-MIDI
         download succeeds, will generate midi (new device for me) and, say com8 (as PID is different, windows will generate different com port)
    download again blink.hex compiled with Serial
         download fails, requires button press, but com8 is clearly indicated.
         (to avoid button press, I opened com8 on terminal with baud 134, which put T3.2 into program mode)
         TD downloads blink.hex
         download succeeds, will generate, again com19
    My hunch is, that teensy_reboot.exe, needs upgrade.
    17,596
    Let's do this as a library from source. Here's a first attempt...
    https://github.com/PaulStoffregen/CryptoAccel
    Apr 2013
    106
    A way to use ssh with the teensy, not only telnet?
    17,596
    SSH requires much more. This could be used as one small piece, but among many other things needed are asymmetric cyphers for key exchange. This library is limited to only computing a few specific symmetric ciphers and one-way hashes. Even for those ciphers, it only does the basic computation. You'd still need to add at least block chaining since ECB mode is not secure.
    Germany NRW
    4,438
    Great, thank you!
    Senior Member Wozzy's Avatar
    341
    Arduino 1.6.10 Keeps Recompiling Core
    Update: Problem Solved by disabling Trend Micro Internet & Micro Security Version 10.0.1288 (see #38)
    I am setting up a new Arduino installation on my Windows 10 PC to start testing my Teensy 3.6
    I created a new directory and unzipped the latest Arduino 1.6.10 download into it.
    I applied Teensyduino 1.30 Beta 2 without problems.
    I have the new boards.txt file from post 910 of the K66 thread but the problem occurs both with the K66 boards.txt file and the Teensyduino 1.30B2 boards.txt file.
    For now I'm just working with a Teensy 3.2.
    It seems like Arduino is trying to recompile the entire core even when just trying to run the blink example.
    This takes close to 20 minutes.
    Here's an example verbose output from the Arduino console:
    C:\Arduino1610Teensyduino130B2\arduino-builder -dump-prefs -logger=machine -hardware "C:\Arduino1610Teensyduino130B2\hardware" -hardware "C:\Users\Bob\AppData\Local\Arduino15\packages" -tools "C:\Arduino1610Teensyduino130B2\tools-builder" -tools "C:\Arduino1610Teensyduino130B2\hardware\tools\avr" -tools "C:\Users\Bob\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Arduino1610Teensyduino130B2\libraries" -libraries "C:\Users\Bob\Documents\Arduino\libraries" -fqbn=teensy:avr:teensy31:usb=serial,speed=96opt,keys=en-us -ide-version=10610 -build-path "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp" -warnings=default -verbose "C:\Arduino1610Teensyduino130B2\examples\Teensy\Tutorial1\Blink\Blink.pde"
    Compiling libraries...
    Compiling core...
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\memcpy-armv7m.S" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\memcpy-armv7m.S.o"
    C:\Arduino1610Teensyduino130B2\arduino-builder -compile -logger=machine -hardware "C:\Arduino1610Teensyduino130B2\hardware" -hardware "C:\Users\Bob\AppData\Local\Arduino15\packages" -tools "C:\Arduino1610Teensyduino130B2\tools-builder" -tools "C:\Arduino1610Teensyduino130B2\hardware\tools\avr" -tools "C:\Users\Bob\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Arduino1610Teensyduino130B2\libraries" -libraries "C:\Users\Bob\Documents\Arduino\libraries" -fqbn=teensy:avr:teensy31:usb=serial,speed=96opt,keys=en-us -ide-version=10610 -build-path "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp" -warnings=default -verbose "C:\Arduino1610Teensyduino130B2\examples\Teensy\Tutorial1\Blink\Blink.pde"
    Using board 'teensy31' from platform in folder: C:\Arduino1610Teensyduino130B2\hardware\teensy\avr
    Using core 'teensy3' from platform in folder: C:\Arduino1610Teensyduino130B2\hardware\teensy\avr
    Detecting libraries used...
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\sketch\Blink.pde.cpp" -o "nul"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\memset.S" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\memset.S.o"
    Generating function prototypes...
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\sketch\Blink.pde.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\analog.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\analog.c.o"
    "C:\Arduino1610Teensyduino130B2\tools-builder\ctags\5.8-arduino10/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
    Compiling sketch...
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\sketch\Blink.pde.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\sketch\Blink.pde.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\eeprom.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\eeprom.c.o"
    Compiling core...
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\memcpy-armv7m.S" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\memcpy-armv7m.S.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\keylayouts.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\keylayouts.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\memset.S" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\memset.S.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\math_helper.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\math_helper.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\analog.c" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\analog.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\mk20dx128.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\mk20dx128.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\eeprom.c" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\eeprom.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\nonstd.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\nonstd.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\keylayouts.c" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\keylayouts.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\pins_teensy.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\pins_teensy.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\math_helper.c" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\math_helper.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\ser_print.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\ser_print.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\mk20dx128.c" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\mk20dx128.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\serial1.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\serial1.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\nonstd.c" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\nonstd.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\serial2.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\serial2.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\pins_teensy.c" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\pins_teensy.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\serial3.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\serial3.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\ser_print.c" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\ser_print.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\serial4.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\serial4.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\serial1.c" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\serial1.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\serial5.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\serial5.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\HardwareSerial6.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\HardwareSerial6.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\Stream.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\Stream.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\IPAddress.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\IPAddress.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\Tone.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\Tone.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\IntervalTimer.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\IntervalTimer.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\WMath.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\WMath.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\Print.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\Print.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\WString.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\WString.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\Stream.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\Stream.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\avr_emulation.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\avr_emulation.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\Tone.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\Tone.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\main.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\main.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\WMath.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\WMath.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\new.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\new.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\WString.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\WString.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\usb_audio.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_audio.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\avr_emulation.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\avr_emulation.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\usb_flightsim.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_flightsim.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\main.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\main.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\usb_inst.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_inst.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\new.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\new.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\yield.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\yield.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\usb_audio.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_audio.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\memcpy-armv7m.S.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\memset.S.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\analog.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\usb_flightsim.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_flightsim.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\eeprom.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\keylayouts.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\math_helper.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\usb_inst.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_inst.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\mk20dx128.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\nonstd.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\pins_teensy.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\yield.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\yield.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\ser_print.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\serial1.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\serial2.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\memcpy-armv7m.S.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\serial3.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\memset.S.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\serial4.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\analog.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\serial5.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\eeprom.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\serial6.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\keylayouts.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\serial6_lpuart.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\math_helper.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\touch.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\mk20dx128.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_desc.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\nonstd.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_dev.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\pins_teensy.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_joystick.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\ser_print.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_keyboard.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\serial1.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_mem.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\serial2.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_midi.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\serial3.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_mouse.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\serial4.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_mtp.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\serial5.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_rawhid.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\serial6.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_seremu.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\serial6_lpuart.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_serial.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\touch.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_touch.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_desc.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\AudioStream.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_dev.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\DMAChannel.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_joystick.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\HardwareSerial1.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_keyboard.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\HardwareSerial2.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_mem.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\HardwareSerial3.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_midi.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\HardwareSerial4.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_mouse.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\HardwareSerial5.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_mtp.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\HardwareSerial6.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_rawhid.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\IPAddress.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_seremu.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\IntervalTimer.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_serial.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\Print.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_touch.c.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\Stream.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\AudioStream.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\Tone.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\DMAChannel.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\WMath.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\HardwareSerial1.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\WString.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\HardwareSerial2.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\avr_emulation.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\HardwareSerial3.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\main.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\HardwareSerial4.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\new.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\HardwareSerial5.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_audio.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\HardwareSerial6.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_flightsim.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\IPAddress.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_inst.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\IntervalTimer.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\yield.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\Print.cpp.o"
    Linking everything together...
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1471185117 "-TC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3/mk20dx256.ld"  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/Blink.pde.elf" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\sketch\Blink.pde.cpp.o" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core\core.a" "-LC:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp" -larm_cortexM4l_math -lm
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\Stream.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\Tone.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\WMath.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/Blink.pde.elf" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/Blink.pde.eep"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\WString.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/Blink.pde.elf" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/Blink.pde.hex"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\avr_emulation.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools//teensy_post_compile" "-file=Blink.pde" "-path=C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp" "-tools=C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/" "-board=TEENSY31"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\main.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\new.cpp.o"
    Sketch uses 14,292 bytes (5%) of program storage space. Maximum is 262,144 bytes.
    Global variables use 3,536 bytes (5%) of dynamic memory, leaving 62,000 bytes for local variables. Maximum is 65,536 bytes.
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_audio.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_flightsim.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_inst.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\yield.cpp.o"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1471185188 "-TC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3/mk20dx256.ld"  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/Blink.pde.elf" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\sketch\Blink.pde.cpp.o" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core\core.a" "-LC:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp" -larm_cortexM4l_math -lm
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/Blink.pde.elf" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/Blink.pde.eep"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/Blink.pde.elf" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/Blink.pde.hex"
    "C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools//teensy_post_compile" "-file=Blink.pde" "-path=C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp" "-tools=C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/" "-board=TEENSY31"
    Sketch uses 14,212 bytes (5%) of program storage space. Maximum is 262,144 bytes.
    C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/teensy_post_compile -test -file=Blink.pde -path=C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp -tools=C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools -board=TEENSY31 -reboot
    Settings are;
    Board: Teensy 3.1/3.2
    USB: Serial
    Keyboard layout: US English
    CPU speed: 96 MHz optimize speed (overclock)
    Port: COM5
    Does anyone know what may be going on here?
    Everything is still fine with my 1.6.9 setup.
    Senior Member Wozzy's Avatar
    341
    I'm still not having any luck.
    It's taking over 20 minutes each time I try to build a sketch with Arduino 1.6.10
    The same Blink sketch in Arduino 1.6.9 takes under 5 seconds to build.
    I verified that the sketch folder is not read-only as discussed here https://forum.pjrc.com/threads/34233...rebuilding-all
    I going to try and redownload and reinstall Arduino again this time using the installer.
    Edit: Well that didn't work either.
    Update: Problem Solved by disabling Trend Micro Internet & Micro Security Version 10.0.1288 (see #38)
    Sep 2013
    7
    Arduino 1.6.10 + Beta Teensyduino + WS8211 = SAD
    FYI, I just spent today trying to figure out what I broke and/or where all the signal noise was coming from. Turn out that Ardunio 1.6.10 + the Teensyduino beta does not produce correct code to drive OctoWS2811. I tried plain FastLED, OctoWS2811 (dma), and a vast array of combinations of cables, Teensy's, level shifters, power supplies, etc
    Downgrading to Arduino 1.6.9 and the non-beta Teensyduino fixed it.
    17,596
    Quote Originally Posted by Zekiel View Post
    Can you save me some time by posting the code to reproduce this problem?
    17,596
    Quote Originally Posted by Wozzy View Post
    Yikes, 20 minutes is horrible.
    Does 1.6.10 do this for Arduino Uno or Arduino Due, or only when compiling for Teensy?
    341
    I don't have any Arduinos to test on, only Teensys. I'll see if I can borrow one from a friend.
    17,596
    No need for a real Arduino. Just select it in the Tools > Boards menu and then click Verify. We're just looking for the compile time, right?
    341
    Yes, good point. Tonight, I'll reload a fresh Arduino 1.6.10, then try to "verify" before and after applying the Teensyduino 1.30B2 update.
