Results 1 to 5 of 5
Thread: Audio adapter input all -1
    Jan 2016
    14
    Feeding a 1V pp 1 KHz square wave into LineIn. All I get is -1. Any ideas?
    #include <SerialFlash.h>
    AudioInputI2S i2s2;
    AudioRecordQueue queue1;
    AudioConnection patchCord1(i2s2, 0, queue1, 0);
    int mode = 0; // 1=stopped, 0=recording
    int Count = 0;
    int Time = 10;
    int NRecords = (Time*AUDIO_SAMPLE_RATE_EXACT*4)/256;
    int led = 13;
    File frec;
    pinMode(led, OUTPUT);
    Serial.begin(57600);
    AudioMemory(60);
    sgtl5000_1.enable();
    sgtl5000_1.volume(0.5);
    // Initialize the SD card
    SPI.setMOSI(7);
    SPI.setSCK(14);
    if (!(SD.begin(10))) {
    while (1) {
    startRecording();
    Count = 0;
    void startRecording() {
    Serial.println("startRecording");
    if (SD.exists("RECORD2.RAW")) {.
    SD.remove("RECORD2.RAW");
    frec = SD.open("RECORD2.RAW", FILE_WRITE);
    if (frec) {
    queue1.begin();
    void flushRecording() {
    Serial.println("flushRecording");
    queue1.end();
    queue1.freeBuffer();
    frec.close();
    byte *b;
    if (mode == 1)
    return;
    Count++;
    b = (byte*)queue1.readBuffer();
    if (Count%100 == 0) {
    Serial.print("record ");
    Serial.println(Count);
    frec.write(b, 256);
    if (Count >= NRecords) {
    flushRecording();
    mode = 1;
    Jan 2016
    14
    Zeroing the buffers when I release them and still I get -1.
    Checked all the solder connections.
    The ground lines are all tied, so that's not it.
    Is there some API setting I'm missing.
    1,416
    Which Teensy are you using and what clock speed is it set at?
    Pete
    1,416
    Found it.
    You can't use pin 13 as the led output because it is used by the audio board as an input.
    Pete
    Jan 2016
    14
    Wahoo!
    Thanks a bunch.
    Just verified it.
    p.s. Teensy 3.1 @ 96 MHz.
    Loren
