vitormhenrique
Question is pretty simple,
I'm having issues sharing the SPI port on teensy-lc. So I want to use the second hardware SPI on it, how do I access it?
It is going to drive an ST7735S TFT Display, I could use software SPI but if I can make the hardware SPI work would be great.
I know that I need to tweak the library, so I'll need to create a new constructor, with the new SPI pins and say that it is indeed hardware SPI.
Current the constructors on the library are, changing this is simple
But when transferring data for the SPI I'm not sure about this part:
How do I call SPI1?
Entire library code is here:
https://github.com/adafruit/Adafruit-ST7735-Library
// Constructor when using software SPI. All output pins are configurable.
Adafruit_ST7735::Adafruit_ST7735(int8_t cs, int8_t rs, int8_t sid, int8_t sclk, int8_t rst)
: Adafruit_GFX(ST7735_TFTWIDTH, ST7735_TFTHEIGHT_18)
_cs = cs;
_rs = rs;
_sid = sid;
_sclk = sclk;
_rst = rst;
hwSPI = false;
// Constructor when using hardware SPI. Faster, but must use SPI pins
// specific to each board type (e.g. 11,13 for Uno, 51,52 for Mega, etc.)
Adafruit_ST7735::Adafruit_ST7735(int8_t cs, int8_t rs, int8_t rst)
: Adafruit_GFX(ST7735_TFTWIDTH, ST7735_TFTHEIGHT_18) {
_cs = cs;
_rs = rs;
_rst = rst;
hwSPI = true;
_sid = _sclk = 0;
if (hwSPI) {
#if defined (SPI_HAS_TRANSACTION)
SPI.transfer(c);
#elif defined (__AVR__)
SPCRbackup = SPCR;
SPCR = mySPCR;
SPI.transfer(c);
SPCR = SPCRbackup;
// SPDR = c;
// while(!(SPSR & _BV(SPIF)));
#elif defined (__arm__)
SPI.setClockDivider(21); //4MHz
SPI.setDataMode(SPI_MODE0);
SPI.transfer(c);
How do I call SPI1?
