I have not checked this issue with other versions of the wiring.h header, but in the hardware/teensy/avr/cores/teensy3 version I found the following issue:
// my original code, which does not work properly, (although it compiles with no errors):
bitWrite(CheckBits, i2, (digitalRead(ports[1][i2])==HIGH)?1:0);
// but this does work (added parenthesis):
bitWrite(CheckBits, i2, ((digitalRead(ports[1][i2])==HIGH)?1:0));
//  the code in wiring.h is
#define bitWrite(value, bit, bitvalue) (bitvalue ? bitSet(value, bit) : bitClear(value, bit))
// I think to fix my problem  it would be more correct to be written:
#define bitWrite(value, bit, bitvalue) ((bitvalue) ? bitSet(value, bit) : bitClear(value, bit))
// and while it might be redundant, since "bitRead" for instance, does put parenthesis around "bit", one could argue that this could be even more correct:
#define bitWrite(value, bit, bitvalue) ((bitvalue) ? bitSet(value, (bit)) : bitClear(value, (bit)))
And yes, after writing the code, and finding the bug, I checked to be sure that HIGH and LOW are defined such that I didn't need the trinary comparison, but the example still points out the problem.
Corey Cooper
