Results 1 to 4 of 4
Thread: union + struct not working (but works on arduino mega)
    Aug 2016
    2
    I am having problems running some code that I succesully tested on the arduino mega. The code receives 5 bytes ('&','@', uint8, uint16) and parses them using a union with a struct inside. This works well on the arduino mega.
    Any ideas on how I can solve this bug?
    I'm working from Windows 10, and I sending the data from Matlab
    #define A_START       '&'
    #define B_START       '@'
    #define HEAD_LENGTH     2
    #define MSG_LENGTH      3
    #define BAUDRATE      115200
    int cnt = 0;        // serial data counter
    // Struct for Data Conversion
    typedef struct {
      union {
        struct {
          uint8_t channel;
          uint16_t val;
        char data[3];
    } convertor;
    convertor packet;
    enum State { st_h1, st_h2, st_data};     // not used
    enum State fromState = st_data;     // not used
      Serial.begin(BAUDRATE);
      Serial1.begin(BAUDRATE);
      Serial1.println("Check!");
      char msg;
      while (Serial.available())
        msg = Serial.read(); cnt++;
        Serial1.println(msg);
        // check if A_START
        if ((msg == A_START) && (cnt == 1))
          cnt++;
        // check if B_START
        else if ((msg == B_START) && (cnt == 2))
          cnt++;
        // read data
        else if (cnt == 3)
          Serial.readBytes(packet.data, 3);
          Serial1.print("Channel: "); Serial1.println(packet.channel);
          uint16_t val = packet.val;
          Serial1.print("TEST: "); Serial1.println(val);
          // Serial1.print("Value: "); Serial1.println(packet.val);
          // Serial1.print("Value: "); Serial1.println(packet.data[1]);
          // Serial1.print("Value: "); Serial1.println(packet.data[2]);
          cnt = 0;
        // force search for heard
            cnt = 0;
    6,112
    Try looking into: #pragma pack
    Different architectures will pack data differently.
    Warning on different machines doing a pack may cause machine faulting. That is some machines do not allow you to access things like words when they are not word aligned...
    Aug 2016
    2
    Thanks KurtE,
    It's my first time learning about '#pragma pack'.
    After googling "teensy pragma pack" I got this thread that already solved this problem
    https://forum.pjrc.com/archive/index.php/t-24940.html
    1,408
    Another option is to use the easy transfer library from bill porter. Very easy to use, very reliable, CRC and all that.
