Results 1 to 12 of 12
Thread: Teensyduino 1.30 Beta #3 Available
    Administrator Paul's Avatar
    Oct 2012
    294
    Here is a third beta test for Teensyduino 1.30.
    Edit: old beta test linkes removed. Full non-beta release is here:
    http://www.pjrc.com/teensy/td_download.html
    Changes since Teensyduino 1.30-beta2:
    • Support for Arduino 1.6.11
    • Teensy 3.5 & 3.6 added to Boards menu
    • Libraries updated: Audio
    3,534
    Downloaded 1.6.11 and then T1.30 beta and it runs on Windows 10 and T3.5 and T3.6 are there.
    I built Blink for T3.6 and verified it works, lost USB serial number at 180mhz, will try with my patch...
    Downloaded 1.6.11 ARM version on on Odroid C2, but see Teensy is not up yet... Will test on there when available.
    Next up: Update MAC.
    Germany NRW
    4,438
    Tried different sketches incl. Audio, with T3.2 and 3.6. Works without problems.
    3,534
    Follow up, I see the ARM version is up there now (comment should probably change).
    I decided to try it and was able to compile and download blink to a T3.2. Yesterday I had someone post a follow on to my Arduino thread saying they were having problems on ARM64 with terminal monitor, so thought I would try. I added simple counter to blink that incremented each time the loop was called and did a Serial.println of the counter...
    I downloaded the program, opened the terminal monitor and nothing output. I left it open did a download, still nothing... Then I noticed lots of output in the command window that I launched the Arduino IDE from, like:
    Sketch uses 17,512 bytes (6%) of program storage space. Maximum is 262,144 bytes.
    Global variables use 4,652 bytes (7%) of dynamic memory, leaving 60,884 bytes for local variables. Maximum is 65,536 bytes.
    Exception in thread "AWT-EventQueue-0" java.lang.NoClassDefFoundError: Could not initialize class jssc.SerialNativeInterface
    	at jssc.SerialPort.<init>(SerialPort.java:120)
    	at processing.app.Serial.<init>(Serial.java:115)
    	at processing.app.Serial.<init>(Serial.java:66)
    	at processing.app.TeensyMonitor$4.<init>(TeensyMonitor.java:131)
    	at processing.app.TeensyMonitor.open(TeensyMonitor.java:131)
    	at processing.app.Editor.handleSerial(Editor.java:2651)
    	at processing.app.EditorToolbar.mousePressed(EditorToolbar.java:384)
    	at java.awt.Component.processMouseEvent(Component.java:6532)
    	at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
    	at java.awt.Component.processEvent(Component.java:6300)
    	at java.awt.Container.processEvent(Container.java:2236)
    	at java.awt.Component.dispatchEventImpl(Component.java:4891)
    	at java.awt.Container.dispatchEventImpl(Container.java:2294)
    	at java.awt.Component.dispatchEvent(Component.java:4713)
    	at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4888)
    	at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4522)
    	at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466)
    	at java.awt.Container.dispatchEventImpl(Container.java:2280)
    	at java.awt.Window.dispatchEventImpl(Window.java:2750)
    	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
    	at java.awt.EventQueue.access$500(EventQueue.java:97)
    	at java.awt.EventQueue$3.run(EventQueue.java:709)
    	at java.awt.EventQueue$3.run(EventQueue.java:703)
    	at java.security.AccessController.doPrivileged(Native Method)
    	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76)
    	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86)
    	at java.awt.EventQueue$4.run(EventQueue.java:731)
    	at java.awt.EventQueue$4.run(EventQueue.java:729)
    	at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
    	at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
    	at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
    	at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
    	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
    	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
    	at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
    Not sure if this is Teensy specific, but did notice the word Teensy in the traceback... Also posted on developer mail list.
    6,441
    IT WORKS to program a T_3.6! :: I just got to my Win 10 DESKTOP and installed IDE 1.6.11, TeensyDuino 1.30b3, and TyQt-0.7.5-187.
    Note - I DID INTEGRATE TYQT to replace TeensyDuino LOADER - I got the anomaly text below - I did not check before I did TYQT - is this because of that?
    Uploading to board 'Unknown' (Teensy 3.6)
    Triggering board reboot
    Firmware: Only_qBlink.ino.hex
    Flash usage: 25 kiB (2.4%)
    Uploading...
    Sending reset command
    UPDATE EDIT:: That text is from TYQT, not IDE or TeensyDuino. It is saying it doesn't know the serial # as the clock speed was too high:
    Uploading to board '2056390-Teensy' (Teensy 3.6)
    Uploading...
    <edit 2> :: the CORE change here works at speeds over 120 MHz.
    105
    Noticed a problem in the boards.txt for Teensy 3.6 and clock frequencies below 24MHz - the speed.xxx and speed.xxx.build.yyy variable names do not match (opt suffix is missing for 2, 4, 8 and 16MHz clock variables). That will cause sketches to not compile due to the missing F_CPU definition.
    Is that intentional for some reason?
    17,622
    Opps, that's a bug. Fixing right now.
    New York
    1,682
    Just tested 1.30b3 on a Teensy 3.2 and the Full Example from the TinyGPS++ lib using a NEO-M8N. Compiled and ran without a hitch even with the GPS baud at 115200. Also, compiled it for the 3.5 and 3.6 with no issues. Will test once I get the new boards.
    Germany NRW
    4,438
    Can you please update FastCRC ?
    17,622
    Done.
    I'm going to look into an issue with FastLED and possibly upgrade or revert to a prior version.
    Then I'm going to release 1.30. We really need a new stable release which supports Arduino 1.6.11.
    I know many requests are pending for Teensy 3.5 and 3.6. I want to get a stable release out first. Then I'm going to merge those and work other integrating SDHC into the Arduino SD library. My goal is a 1.31 release sometime in late October or early November which really supports the new boards well. But at the rate things are going, if I don't wrap up 1.30 it'll keep getting delayed as more stuff needs to be changed for the new boards.
    2,718
    Post
    I think I had reported this earlier, but in case I hadn't or it got missed, if you try to compile the Teensy3.1_eyes program from https://github.com/adafruit/Teensy3.1_Eyes, changing it to use Adafruit_ST7735.h instead of Adafruit_SSD1351.h to use the 128x128 TFT displays, you get the following error:
    uncannyEyes: In function 'void setup()':
    uncannyEyes:105: error: 'INITR_144GREENTAB' was not declared in this scope
         eye[e].display.initR(INITR_144GREENTAB);
    uncannyEyes: In function 'void frame(uint16_t)':
    uncannyEyes:327: warning: comparison between signed and unsigned integer expressions
         if((t - eye[eyeIndex].blink.startTime) >= eye[eyeIndex].blink.duration) {
    uncannyEyes:404: warning: comparison between signed and unsigned integer expressions
         if(s >= eye[eyeIndex].blink.duration) s = 255;   // At or past blink end
    It looks like the change to add INITR_144GREENTAB was: https://github.com/adafruit/Adafruit...1023196a9a157e
    Here is my version of the uncannyEyes file:
    // Uncanny eyes for PJRC Teensy 3.1 with Adafruit 1.5" OLED (product #1431)
    // or 1.44" TFT LCD (#2088).  This uses Teensy-3.1-specific features and
    // WILL NOT work on normal Arduino or other boards!  Use 72 MHz (Optimized)
    // board speed -- OLED does not work at 96 MHz.
    // Adafruit invests time and resources providing this open source code,
    // please support Adafruit and open-source hardware by purchasing products
    // from Adafruit!
    // Written by Phil Burgess / Paint Your Dragon for Adafruit Industries.
    // MIT license.  SPI FIFO insight from Paul Stoffregen's ILI9341_t3 library.
    // Inspired by David Boccabella's (Marcwolf) hybrid servo/OLED eye concept.
    #include <Adafruit_GFX.h>      // Core graphics lib for Adafruit displays
    // Enable ONE of these #includes -- HUGE graphics tables for various eyes:
    #include "defaultEye.h"        // Standard human-ish hazel eye
    //#include "noScleraEye.h"       // Large iris, no sclera
    //#include "dragonEye.h"         // Slit pupil fiery dragon/demon eye
    //#include "goatEye.h"           // Horizontal pupil goat/Krampus eye
    // Then tweak settings below, e.g. change IRIS_MIN/MAX or disable TRACKING.
    // DISPLAY HARDWARE CONFIG -------------------------------------------------
    //#include <Adafruit_SSD1351.h>  // OLED display library -OR-
    #include <Adafruit_ST7735.h> // TFT display library (enable one only)
    #ifdef _ADAFRUIT_ST7735H_
    typedef Adafruit_ST7735  displayType; // Using TFT display(s)
    #else
    typedef Adafruit_SSD1351 displayType; // Using OLED display(s)
    #define DISPLAY_DC      7 // Data/command pin for BOTH displays
    #define DISPLAY_RESET   8 // Reset pin for BOTH displays
    #define SELECT_L_PIN    9 // LEFT eye chip select pin
    #define SELECT_R_PIN   10 // RIGHT eye chip select pin
    // INPUT CONFIG (for eye motion -- enable or comment out as needed) --------
    //#define JOYSTICK_X_PIN A0 // Analog pin for eye horiz pos (else auto)
    //#define JOYSTICK_Y_PIN A1 // Analog pin for eye vert position (")
    //#define JOYSTICK_X_FLIP   // If set, reverse stick X axis
    //#define JOYSTICK_Y_FLIP   // If set, reverse stick Y axis
    #define TRACKING          // If enabled, eyelid tracks pupil
    #define IRIS_PIN       A2 // Photocell or potentiometer (else auto iris)
    //#define IRIS_PIN_FLIP     // If set, reverse reading from dial/photocell
    #define IRIS_SMOOTH       // If enabled, filter input from IRIS_PIN
    #define IRIS_MIN      120 // Clip lower analogRead() range from IRIS_PIN
    #define IRIS_MAX      720 // Clip upper "
    #define WINK_L_PIN      0 // Pin for LEFT eye wink button
    #define BLINK_PIN       1 // Pin for blink button (BOTH eyes)
    #define WINK_R_PIN      2 // Pin for RIGHT eye wink button
    #define AUTOBLINK         // If enabled, eyes blink autonomously
    // Probably don't need to edit any config below this line, -----------------
    // unless building a single-eye project (pendant, etc.), in which case one
    // of the two elements in the eye[] array further down can be commented out.
    // Eye blinks are a tiny 3-state machine.  Per-eye allows winks + blinks.
    #define NOBLINK 0     // Not currently engaged in a blink
    #define ENBLINK 1     // Eyelid is currently closing
    #define DEBLINK 2     // Eyelid is currently opening
    typedef struct {
      int8_t   pin;       // Optional button here for indiv. wink
      uint8_t  state;     // NOBLINK/ENBLINK/DEBLINK
      int32_t  duration;  // Duration of blink state (micros)
      uint32_t startTime; // Time (micros) of last state change
    } eyeBlink;
    struct {
      displayType display; // OLED/TFT object
      uint8_t     cs;      // Chip select pin
      eyeBlink    blink;   // Current blink state
    } eye[] = { // OK to comment out one of these for single-eye display:
      displayType(SELECT_L_PIN,DISPLAY_DC,0),SELECT_L_PIN,{WINK_L_PIN,NOBLINK},
      displayType(SELECT_R_PIN,DISPLAY_DC,0),SELECT_R_PIN,{WINK_R_PIN,NOBLINK},
    #define NUM_EYES (sizeof(eye) / sizeof(eye[0]))
    // INITIALIZATION -- runs once at startup ----------------------------------
    void setup(void) {
      uint8_t e;
      randomSeed(analogRead(A3)); // Seed random() from floating analog input
      // Both displays share a common reset line; 0 is passed to display
      // constructor (so no reset in begin()) -- must reset manually here:
      pinMode(DISPLAY_RESET, OUTPUT);
      digitalWrite(DISPLAY_RESET, LOW);  delay(1);
      digitalWrite(DISPLAY_RESET, HIGH); delay(50);
      for(e=0; e<NUM_EYES; e++) { // Deselect all
        pinMode(eye[e].cs, OUTPUT);
        digitalWrite(eye[e].cs, HIGH);
        digitalWrite(eye[e].cs, LOW); // Select one eye for init
    #ifdef _ADAFRUIT_ST7735H_ // TFT
    #else // OLED
        eye[e].display.begin();
        if(eye[e].blink.pin >= 0) pinMode(eye[e].blink.pin, INPUT_PULLUP);
        digitalWrite(eye[e].cs, HIGH); // Deselect
    #ifdef BLINK_PIN
      pinMode(BLINK_PIN, INPUT_PULLUP);
      // One of the displays is configured to mirror on the X axis.  Simplifies
      // eyelid handling in the drawEye() function -- no need for distinct
      // L-to-R or R-to-L inner loops.  Just the X coordinate of the iris is
      // then reversed when drawing this eye, so they move the same.  Magic!
      digitalWrite(eye[0].cs , LOW);
      digitalWrite(DISPLAY_DC, LOW);
      SPI.transfer(ST7735_MADCTL);
      digitalWrite(DISPLAY_DC, HIGH);
      SPI.transfer(0x88); // MADCTL_MY | MADCTL_BGR
      digitalWrite(eye[0].cs , HIGH);
    #else // OLED
      eye[0].display.writeCommand(SSD1351_CMD_SETREMAP);
      eye[0].display.writeData(0x76);
    // EYE-RENDERING FUNCTION --------------------------------------------------
    SPISettings settings(24000000, MSBFIRST, SPI_MODE3); // Teensy 3.1 max SPI
    void drawEye( // Renders one eye.  Inputs must be pre-clipped & valid.
      uint8_t  e,       // Eye array index; 0 or 1 for left/right
      uint32_t iScale,  // Scale factor for iris
      uint8_t  scleraX, // First pixel X offset into sclera image
      uint8_t  scleraY, // First pixel Y offset into sclera image
      uint8_t  uT,      // Upper eyelid threshold value
      uint8_t  lT) {    // Lower eyelid threshold value
      uint8_t  screenX, screenY, scleraXsave;
      int16_t  irisX, irisY;
      uint16_t p, a;
      uint32_t d;
      // Set up raw pixel dump to entire screen.  Although such writes can wrap
      // around automatically from end of rect back to beginning, the region is
      // reset on each frame here in case of an SPI glitch.
      SPI.beginTransaction(settings);
      eye[e].display.setAddrWindow(0, 0, 127, 127);
    #else // OLED
      eye[e].display.writeCommand(SSD1351_CMD_SETROW);    // Y range
      eye[e].display.writeData(0); eye[e].display.writeData(SCREEN_HEIGHT - 1);
      eye[e].display.writeCommand(SSD1351_CMD_SETCOLUMN); // X range
      eye[e].display.writeData(0); eye[e].display.writeData(SCREEN_WIDTH  - 1);
      eye[e].display.writeCommand(SSD1351_CMD_WRITERAM);  // Begin write
      digitalWrite(eye[e].cs, LOW);                       // Chip select
      digitalWrite(DISPLAY_DC, HIGH);                     // Data mode
      // Now just issue raw 16-bit values for every pixel...
      scleraXsave = scleraX; // Save initial X value to reset on each line
      irisY       = scleraY - (SCLERA_HEIGHT - IRIS_HEIGHT) / 2;
      for(screenY=0; screenY<SCREEN_HEIGHT; screenY++, scleraY++, irisY++) {
        scleraX = scleraXsave;
        irisX   = scleraXsave - (SCLERA_WIDTH - IRIS_WIDTH) / 2;
        for(screenX=0; screenX<SCREEN_WIDTH; screenX++, scleraX++, irisX++) {
          if((lower[screenY][screenX] <= lT) ||
             (upper[screenY][screenX] <= uT)) {             // Covered by eyelid
            p = 0;
          } else if((irisY < 0) || (irisY >= IRIS_HEIGHT) ||
                    (irisX < 0) || (irisX >= IRIS_WIDTH)) { // In sclera
            p = sclera[scleraY][scleraX];
          } else {                                          // Maybe iris...
            p = polar[irisY][irisX];                        // Polar angle/dist
            d = (iScale * (p & 0x7F)) / 128;                // Distance (Y)
            if(d < IRIS_MAP_HEIGHT) {                       // Within iris area
              a = (IRIS_MAP_WIDTH * (p >> 7)) / 512;        // Angle (X)
              p = iris[d][a];                               // Pixel = iris
            } else {                                        // Not in iris
              p = sclera[scleraY][scleraX];                 // Pixel = sclera
          // SPI FIFO technique from Paul Stoffregen's ILI9341_t3 library:
          while(KINETISK_SPI0.SR & 0xC000); // Wait for space in FIFO
          KINETISK_SPI0.PUSHR = p | SPI_PUSHR_CTAS(1) | SPI_PUSHR_CONT;
      KINETISK_SPI0.SR |= SPI_SR_TCF;         // Clear transfer flag
      while((KINETISK_SPI0.SR & 0xF000) ||    // Wait for SPI FIFO to drain
           !(KINETISK_SPI0.SR & SPI_SR_TCF)); // Wait for last bit out
      SPI.endTransaction();
    // EYE ANIMATION -----------------------------------------------------------
    const uint8_t ease[] = { // Ease in/out curve for eye movements 3*t^2-2*t^3
        0,  0,  0,  0,  0,  0,  0,  1,  1,  1,  1,  1,  2,  2,  2,  3,   // T
        3,  3,  4,  4,  4,  5,  5,  6,  6,  7,  7,  8,  9,  9, 10, 10,   // h
       11, 12, 12, 13, 14, 15, 15, 16, 17, 18, 18, 19, 20, 21, 22, 23,   // x
       24, 25, 26, 27, 27, 28, 29, 30, 31, 33, 34, 35, 36, 37, 38, 39,   // 2
       40, 41, 42, 44, 45, 46, 47, 48, 50, 51, 52, 53, 54, 56, 57, 58,   // A
       60, 61, 62, 63, 65, 66, 67, 69, 70, 72, 73, 74, 76, 77, 78, 80,   // l
       81, 83, 84, 85, 87, 88, 90, 91, 93, 94, 96, 97, 98,100,101,103,   // e
      104,106,107,109,110,112,113,115,116,118,119,121,122,124,125,127,   // c
      128,130,131,133,134,136,137,139,140,142,143,145,146,148,149,151,   // J
      152,154,155,157,158,159,161,162,164,165,167,168,170,171,172,174,   // a
      175,177,178,179,181,182,183,185,186,188,189,190,192,193,194,195,   // c
      197,198,199,201,202,203,204,205,207,208,209,210,211,213,214,215,   // o
      216,217,218,219,220,221,222,224,225,226,227,228,228,229,230,231,   // b
      232,233,234,235,236,237,237,238,239,240,240,241,242,243,243,244,   // s
      245,245,246,246,247,248,248,249,249,250,250,251,251,251,252,252,   // o
      252,253,253,253,254,254,254,254,254,255,255,255,255,255,255,255 }; // n
    #ifdef AUTOBLINK
    uint32_t timeOfLastBlink = 0L, timeToNextBlink = 0L;
    void frame( // Process motion for a single frame of left or right eye
      uint16_t        iScale) {     // Iris scale (0-1023) passed in
      static uint32_t frames   = 0; // Used in frame rate calculation
      static uint8_t  eyeIndex = 0; // eye[] array counter
      int16_t         eyeX, eyeY;
      uint32_t        t = micros(); // Time at start of function
      Serial.println((++frames * 1000) / millis()); // Show frame rate
      if(++eyeIndex >= NUM_EYES) eyeIndex = 0; // Cycle through eyes, 1 per call
      // X/Y movement
    #if defined(JOYSTICK_X_PIN) && (JOYSTICK_X_PIN >= 0) && \
        defined(JOYSTICK_Y_PIN) && (JOYSTICK_Y_PIN >= 0)
      // Read X/Y from joystick, constrain to circle
      int16_t dx, dy;
      int32_t d;
      eyeX = analogRead(JOYSTICK_X_PIN); // Raw (unclipped) X/Y reading
      eyeY = analogRead(JOYSTICK_Y_PIN);
    #ifdef JOYSTICK_X_FLIP
      eyeX = 1023 - eyeX;
    #ifdef JOYSTICK_Y_FLIP
      eyeY = 1023 - eyeY;
      dx = (eyeX * 2) - 1023; // A/D exact center is at 511.5.  Scale coords
      dy = (eyeY * 2) - 1023; // X2 so range is -1023 to +1023 w/center at 0.
      if((d = (dx * dx + dy * dy)) > (1023 * 1023)) { // Outside circle
        d    = (int32_t)sqrt((float)d);               // Distance from center
        eyeX = ((dx * 1023 / d) + 1023) / 2;          // Clip to circle edge,
        eyeY = ((dy * 1023 / d) + 1023) / 2;          // scale back to 0-1023
    #else // Autonomous X/Y eye motion
          // Periodically initiates motion to a new random point, random speed,
          // holds there for random period until next motion.
      static boolean  eyeInMotion      = false;
      static int16_t  eyeOldX=512, eyeOldY=512, eyeNewX=512, eyeNewY=512;
      static uint32_t eyeMoveStartTime = 0L;
      static int32_t  eyeMoveDuration  = 0L;
      int32_t dt = t - eyeMoveStartTime;      // uS elapsed since last eye event
      if(eyeInMotion) {                       // Currently moving?
        if(dt >= eyeMoveDuration) {           // Time up?  Destination reached.
          eyeInMotion      = false;           // Stop moving
          eyeMoveDuration  = random(3000000); // 0-3 sec stop
          eyeMoveStartTime = t;               // Save initial time of stop
          eyeX = eyeOldX = eyeNewX;           // Save position
          eyeY = eyeOldY = eyeNewY;
        } else { // Move time's not yet fully elapsed -- interpolate position
          int16_t e = ease[255 * dt / eyeMoveDuration] + 1;   // Ease curve
          eyeX = eyeOldX + (((eyeNewX - eyeOldX) * e) / 256); // Interp X
          eyeY = eyeOldY + (((eyeNewY - eyeOldY) * e) / 256); // and Y
      } else {                                // Eye stopped
        eyeX = eyeOldX;
        eyeY = eyeOldY;
        if(dt > eyeMoveDuration) {            // Time up?  Begin new move.
          int16_t  dx, dy;
          uint32_t d;
          do {                                // Pick new dest in circle
            eyeNewX = random(1024);
            eyeNewY = random(1024);
            dx      = (eyeNewX * 2) - 1023;
            dy      = (eyeNewY * 2) - 1023;
          } while((d = (dx * dx + dy * dy)) > (1023 * 1023)); // Keep trying
          eyeMoveDuration  = random(72000, 144000); // ~1/14 - ~1/7 sec
          eyeMoveStartTime = t;               // Save initial time of move
          eyeInMotion      = true;            // Start move on next frame
    #endif // JOYSTICK_X_PIN etc.
      // Blinking
    #ifdef AUTOBLINK
      // Similar to the autonomous eye movement above -- blink start times
      // and durations are random (within ranges).
      if((t - timeOfLastBlink) >= timeToNextBlink) { // Start new blink?
        timeOfLastBlink = t;
        uint32_t blinkDuration = random(36000, 72000); // ~1/28 - ~1/14 sec
        // Set up durations for both eyes (if not already winking)
        for(uint8_t e=0; e<NUM_EYES; e++) {
          if(eye[e].blink.state == NOBLINK) {
            eye[e].blink.state     = ENBLINK;
            eye[e].blink.startTime = t;
            eye[e].blink.duration  = blinkDuration;
        timeToNextBlink = blinkDuration * 3 + random(4000000);
      if(eye[eyeIndex].blink.state) { // Eye currently blinking?
        // Check if current blink state time has elapsed
          // Yes -- increment blink state, unless...
          if((eye[eyeIndex].blink.state == ENBLINK) &&  // Enblinking and...
            ((digitalRead(BLINK_PIN) == LOW) ||         // blink or wink held...
              digitalRead(eye[eyeIndex].blink.pin) == LOW)) {
            // Don't advance state yet -- eye is held closed instead
          } else { // No buttons, or other state...
            if(++eye[eyeIndex].blink.state > DEBLINK) { // Deblinking finished?
              eye[eyeIndex].blink.state = NOBLINK;      // No longer blinking
            } else { // Advancing from ENBLINK to DEBLINK mode
              eye[eyeIndex].blink.duration *= 2; // DEBLINK is 1/2 ENBLINK speed
              eye[eyeIndex].blink.startTime = t;
      } else { // Not currently blinking...check buttons!
        if(digitalRead(BLINK_PIN) == LOW) {
          // Manually-initiated blinks have random durations like auto-blink
        } else if(digitalRead(eye[eyeIndex].blink.pin) == LOW) { // Wink!
          eye[eyeIndex].blink.state     = ENBLINK;
          eye[eyeIndex].blink.duration  = random(45000, 90000);
      // Process motion, blinking and iris scale into renderable values
      // Iris scaling: remap from 0-1023 input to iris map height pixel units
      iScale = ((IRIS_MAP_HEIGHT + 1) * 1024) /
               (1024 - (iScale * (IRIS_MAP_HEIGHT - 1) / IRIS_MAP_HEIGHT));
      // Scale eye X/Y positions (0-1023) to pixel units used by drawEye()
      eyeX = map(eyeX, 0, 1023, 0, SCLERA_WIDTH  - 128);
      eyeY = map(eyeY, 0, 1023, 0, SCLERA_HEIGHT - 128);
      if(eyeIndex == 1) eyeX = (SCLERA_WIDTH - 128) - eyeX; // Mirrored display
      // Horizontal position is offset so that eyes are very slightly crossed
      // to appear fixated (converged) at a conversational distance.  Number
      // here was extracted from my posterior and not mathematically based.
      // I suppose one could get all clever with a range sensor, but for now...
      eyeX += 4;
      if(eyeX > (SCLERA_WIDTH - 128)) eyeX = (SCLERA_WIDTH - 128);
      // Eyelids are rendered using a brightness threshold image.  This same
      // map can be used to simplify another problem: making the upper eyelid
      // track the pupil (eyes tend to open only as much as needed -- e.g. look
      // down and the upper eyelid drops).  Just sample a point in the upper
      // lid map slightly above the pupil to determine the rendering threshold.
      static uint8_t uThreshold = 128;
      uint8_t        lThreshold, n;
    #ifdef TRACKING
      int16_t sampleX = SCLERA_WIDTH  / 2 - (eyeX / 2), // Reduce X influence
              sampleY = SCLERA_HEIGHT / 2 - (eyeY + IRIS_HEIGHT / 4);
      // Eyelid is slightly asymmetrical, so two readings are taken, averaged
      if(sampleY < 0) n = 0;
      else            n = (upper[sampleY][sampleX] +
                           upper[sampleY][SCREEN_WIDTH - 1 - sampleX]) / 2;
      uThreshold = (uThreshold * 3 + n) / 4; // Filter/soften motion
      // Lower eyelid doesn't track the same way, but seems to be pulled upward
      // by tension from the upper lid.
      lThreshold = 254 - uThreshold;
    #else // No tracking -- eyelids full open unless blink modifies them
      uThreshold = lThreshold = 0;
      // The upper/lower thresholds are then scaled relative to the current
      // blink position so that blinks work together with pupil tracking.
        uint32_t s = (t - eye[eyeIndex].blink.startTime);
        else s = 255 * s / eye[eyeIndex].blink.duration; // Mid-blink
        s          = (eye[eyeIndex].blink.state == DEBLINK) ? 1 + s : 256 - s;
        n          = (uThreshold * s + 254 * (257 - s)) / 256;
        lThreshold = (lThreshold * s + 254 * (257 - s)) / 256;
        n          = uThreshold;
      // Pass all the derived values to the eye-rendering function:
      drawEye(eyeIndex, iScale, eyeX, eyeY, n, lThreshold);
    // AUTONOMOUS IRIS SCALING (if no photocell or dial) -----------------------
    #if !defined(IRIS_PIN) || (IRIS_PIN < 0)
    // Autonomous iris motion uses a fractal behavior to similate both the major
    // reaction of the eye plus the continuous smaller adjustments that occur.
    uint16_t oldIris = (IRIS_MIN + IRIS_MAX) / 2, newIris;
    void split( // Subdivides motion path into two sub-paths w/randimization
      int16_t  startValue, // Iris scale value (IRIS_MIN to IRIS_MAX) at start
      int16_t  endValue,   // Iris scale value at end
      uint32_t startTime,  // micros() at start
      int32_t  duration,   // Start-to-end time, in microseconds
      int16_t  range) {    // Allowable scale value variance when subdividing
      if(range >= 8) {     // Limit subdvision count, because recursion
        range    /= 2;     // Split range & time in half for subdivision,
        duration /= 2;     // then pick random center point within range:
        int16_t  midValue = (startValue + endValue - range) / 2 + random(range);
        uint32_t midTime  = startTime + duration;
        split(startValue, midValue, startTime, duration, range); // First half
        split(midValue  , endValue, midTime  , duration, range); // Second half
      } else {             // No more subdivisons, do iris motion...
        int32_t dt;        // Time (micros) since start of motion
        int16_t v;         // Interim value
        while((dt = (micros() - startTime)) < duration) {
          v = startValue + (((endValue - startValue) * dt) / duration);
          if(v < IRIS_MIN)      v = IRIS_MIN; // Clip just in case
          else if(v > IRIS_MAX) v = IRIS_MAX;
          frame(v);        // Draw frame w/interim iris scale value
    #endif // !IRIS_PIN
    // MAIN LOOP -- runs continuously after setup() ----------------------------
    #if defined(IRIS_PIN) && (IRIS_PIN >= 0) // Interactive iris
      uint16_t v = analogRead(IRIS_PIN);       // Raw dial/photocell reading
    #ifdef IRIS_PIN_FLIP
      v = 1023 - v;
      v = map(v, 0, 1023, IRIS_MIN, IRIS_MAX); // Scale to iris range
    #ifdef IRIS_SMOOTH // Filter input (gradual motion)
      static uint16_t irisValue = (IRIS_MIN + IRIS_MAX) / 2;
      irisValue = ((irisValue * 15) + v) / 16;
      frame(irisValue);
    #else // Unfiltered (immediate motion)
      frame(v);
    #endif // IRIS_SMOOTH
    #else  // Autonomous iris scaling -- invoke recursive function
    #endif // !IRIS_PIN
      v = 1023 - v;
      frame(irisValue);
      frame(v);
      newIris = random(IRIS_MIN, IRIS_MAX);
      split(oldIris, newIris, micros(), 10000000L, IRIS_MAX - IRIS_MIN);
      oldIris = newIris;
    #endif // IRIS_PIN
    My changes were:
    $ cvs diff -r1.1 uncannyEyes.ino
    diff -p -c -r1.1 -r1.2
    *** uncannyEyes.ino     2 Aug 2016 04:46:47 -0000       1.1
    --- uncannyEyes.ino     2 Aug 2016 13:13:37 -0000       1.2
    *** 24,31 ****
    ! #include <Adafruit_SSD1351.h>  // OLED display library -OR-
    ! //#include <Adafruit_ST7735.h> // TFT display library (enable one only)
    --- 24,31 ----
    ! //#include <Adafruit_SSD1351.h>  // OLED display library -OR-
    ! #include <Adafruit_ST7735.h> // TFT display library (enable one only)
    *************** void split( // Subdivides motion path in
    *** 457,463 ****
    ! #ifdef IRIS_PIN && (IRIS_PIN >= 0) // Interactive iris
    --- 457,463 ----
    ! #if defined(IRIS_PIN) && (IRIS_PIN >= 0) // Interactive iris
    thanks for update
