Hi there!
I'm currently building a project and I've been asked if I can output MIDI Show Control from a Teensy.
In theory this can be done using MIDI SYSEX commands correct? In all the reading I've done the string I need is as follows
F0 7F 127 02 7F 01 F7
Which will issue a "Go" command to device 127.
I however can't for the life of me get the string to compile so I figure I must be missing something right?
if (Go.fallingEdge()) {
usbMIDI.sendSysEx(7, F7 7F 127 02 7F 01 F0);
analogWrite(LED, dim);
delay(250);
This piece of code is looking for the pressing of a button I've called "Go", and it should output the SysEx message correct?
Or am I barking totally up the wrong tree?
Currently it won't compile, it comes up with an error that I "haven't defined F7"
Any guidence would be much appreciated!!
-Rory Maguire
delay(250);
-Rory Maguire
