Results 1 to 6 of 6
Thread: Nit pick on 3.6 kick starter maybe?
    May 2015
    402
    Nit pick on 3.6 kick starter maybe? SD/micoSD
    It looks like the SD card slot is for a micro SD Card. I not 100% sure but the connector looks about a 1/2 inch wide and standard SD card is close to an inch wide. Maybe the Kickstarter page should say as much as I was looking to see if I had to go find a full size card before it ships. All of mine are micro size from my older smart phones. Apple freed me from having that choice.
    7,679
    Yes Micro SD
    22,756
    I've edited the text to add "micro" in 2 of the 3 places where "SD" appears. Hopefully that helps?
    12,406
    Another nit - it might be better if the T_3.5 said 'No Touch Sensing Inputs'
    May 2015
    402
    Thanks! Like I said it was a very minor point, I almost didn't even bother to bring it up.
    12,406
    Not a nit - just a link . . .
    Paul shows a T_3.6 USB 'motherboard' to TYPE A connector on KS.
    This USB port is accessed using 5 pins, which are compatible with the commonly available internal PC cables for USB.
    I just found this Amazon link to a similar (non-panel mount) version that would be female to USB pin header to female USB A.
Tags for this Thread
