Results 1 to 4 of 4
Thread: Teensy LC max SPI Speed
    Aug 2016
    Germany
    2
    Hey,
    I played a little bit with the Teensy LC SPI and discovered that I can't get more than 12MHz at the SCK pin. Is this the maximum setting for the Teensy LC or am I doing something wrong?
    Her is my test code:
      SPI.begin();
      SPI.beginTransaction(SPISettings(24000000, MSBFIRST, SPI_MODE0)); // This outputs only a 12MHz Clock on the SCK pin
      SPI.transfer(255);
      SPI.endTransaction();
      delay(10);
    20,558
    On LC, the max SPI clock is 12 MHz.
    5,421
    I could be wrong, but my quick check is that the SPI speed has a max of F_BUS/2 on the Teensy LC and at MAX CPU of 48mhz, F_BUS set to 24mhz and so half 24/2 = 12mhz
    Kurt
    Aug 2016
    Germany
    2
    Ah ok I thought F_BUS would be 48MHz.
    Thanks for the correction.
