lennon-pledge
New member
Here's the general layout of what I'm trying to do.
In LabView, I have an FPGA that sends a byte of information to my Teensy via SPI. The Teensy acts a slave in this case, the FPGA being the master.
What I want to do next is take that byte (let's say it's 150 in decimal), and use it to test an "if" condition in order to light an LED. This "if" condition being built into the chip on the Teensy.
This is where I want to introduce an SPI-incorporated single-channel digital pot (MCP4151). If the byte in decimal form being transferred is 150, I want to use the Teensy to send 150 to the digital pot to represent the wiper step. The MCP4151 has 0-255 steps, and it's a 50k ohm max. If the 150 gets there, my LED will light up to such a brightness.
Before I try that second task I want to know if this is even possible? Using the Teensy first as a slave, then as a master. Or any other Arduino board for that matter (I will get the necessary board if need be).
