DJ Namaste
Hello
I am working on making a hula hoop. Previously I have trimmed down the edges of the teensy 3.2 by cutting the pins off from pin 13 and up and just using the pins on the opposite side. It has worked for me in the past and this time around with the board I purchased a couple weeks ago, it is not working.
Is there some connection between the pins to the main ground or voltage? It will not load the blink sketch now and Ive tried using alternative power to voltage and ground in addition to the usb. I haven't modified it other than cutting off the pins on the 13-25, gnd etc so it would fit in the tubing.
Maybe the cutting process caused a static charge that blew something? Teensy have always been recoverable for me most of the time so im wondering what I can do to fix it.
Chris
Chris
