rarefaction
New member
I am a n00b at Arduino code and although i understand syntax of other languages and i can chop and change pieces of code from all over the place to generally do what i want to do.. i am completely stumped on how to get the usb midi from teensy to output to a pin..
I read through all of the references and still i don't get it and there are no examples of midi output as such... at least not midi data just a flashing LED.. basically I have a teensy 3.2 with audio adapter shield which i want to pass midi data out from the teensy USB device in Ableton to a DSP-G1 chip. I already have the audio passing through fine and the chip is working with another additional USB Midi interface i happen to have however i need help writing the code for relaying midi data from the teensy USB midi output device to a pin (i'm assuming TX) that can deliver a TTL midi signal for the DSP-G1 synth chip.
Any tips, or advice I have no idea where to start really..
Thanks,
rf
Thanks,
rf
