Have tried a few variations of code on different machines.
Get basically the same errors in all case.
OUTPUT / ERRORS:
Serial Ports List:
/dev/cu.Bluetooth-Incoming-Port /dev/cu.usbmodem1508001 /dev/tty.Bluetooth-Incoming-Port /dev/tty.usbmodem1508001
port 0: 0
2016-08-29 20:01:22.658 java[7412:1898297] 20:01:22.658 WARNING: 140: This application, or a library it uses, is using the deprecated Carbon Component Manager for hosting Audio Units. Support for this will be removed in a future release. Also, this makes the host incompatible with version 3 audio units. Please transition to the API's in AudioComponent.h.
error, disabling movieEvent() for /Volumes/Untitled/Users/Dirkblaze/Movies/Semaphore.avi
java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Nativ e Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Native MethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(De legatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at processing.video.Movie.fireMovieEvent(Unknown Source)
at processing.video.Movie.invokeEvent(Unknown Source)
at processing.video.Movie$2.rgbFrame(Unknown Source)
at org.gstreamer.elements.RGBDataAppSink$AppSinkNewBu fferListener.newBuffer(RGBDataAppSink.java:162)
at org.gstreamer.elements.AppSink$2.callback(AppSink. java:184)
at com.sun.jna.CallbackReference$DefaultCallbackProxy .invokeCallback(CallbackReference.java:485)
at com.sun.jna.CallbackReference$DefaultCallbackProxy .callback(CallbackReference.java:515)
Caused by: java.lang.ArrayIndexOutOfBoundsException: 2400
at movie2serial.image2data(movie2serial.java:186)
at movie2serial.movieEvent(movie2serial.java:129)
... 15 more
CODE:
import processing.video.*;
import processing.serial.*;
import java.awt.Rectangle;
Movie myMovie;
final int SCREEN_WIDTH = 50;
final int SCREEN_HEIGHT = 16;
final int PANEL_WIDTH=100;
final int PANEL_HEIGHT=100;
final int PANELS_PER_PIN = 1;
final int LEDS_PER_STRIP = PANEL_WIDTH * PANEL_HEIGHT * PANELS_PER_PIN;
float gamma = 1.7;
int numPorts=0; // the number of serial ports in use
int maxPorts=24; // maximum number of serial ports
Serial[] ledSerial = new Serial[maxPorts]; // each port's actual Serial port
Rectangle[] ledArea = new Rectangle[maxPorts]; // the area of the movie each port gets, in % (0-100)
boolean[] ledLayout = new boolean[maxPorts]; // layout of rows, true = even is left->right
PImage[] ledImage = new PImage[maxPorts]; // image sent to each port
int[] gammatable = new int[256];
int errorCount=0;
int errorNumber=0;
int i=0;
float framerate=0;
String[] list = Serial.list();
myMovie = new Movie(this, "/Volumes/Untitled/Users/Dirkblaze/Movies/Semaphore.avi");
delay(2);
println("Serial Ports List:");
println(list);
serialConfigure("/dev/tty.usbmodem1508001"); // change these to your port name
if (errorCount > 0) exit();
for (int i=0; i < 255; i++) {
gammatable[i] = (int)(pow((float)i / 255.0, gamma) * 255.0 + 0.5);
size(1024,768); // create the window
myMovie.loop(); // start the movie :-)
// movieEvent runs for each new frame of movie data
void movieEvent(Movie m) {
// read the movie's next frame
m.read();
//if (framerate == 0) framerate = m.getSourceFrameRate();
framerate = 30.0; // TODO, how to read the frame rate???
for (int i=0; i < numPorts; i++) {
// copy a portion of the movie's image to the LED image
int xoffset = percentage(m.width, ledArea[i].x);
int yoffset = percentage(m.height, ledArea[i].y);
int xwidth = percentage(m.width, ledArea[i].width);
int yheight = percentage(m.height, ledArea[i].height);
ledImage[i].copy(m, xoffset, yoffset, xwidth, yheight,
0, 0, ledImage[i].width, ledImage[i].height);
// convert the LED image to raw data
byte[] ledData = new byte[(ledImage[i].width * ledImage[i].height * 3) + 3];
image2data(ledImage[i], ledData, ledLayout[i]);/*
if (i == 0) {
ledData[0] = '*'; // first Teensy is the frame sync master
int usec = (int)((1000000.0 / framerate) * 0.75);
ledData[1] = (byte)(usec); // request the frame sync pulse
ledData[2] = (byte)(usec >> 8); // at 75% of the frame time
ledData[0] = '%'; // others sync to the master board
ledData[1] = 0;
ledData[2] = 0;
// send the raw data to the LEDs :-)
ledSerial[i].write(ledData);
int led_map(int input) {
int row = input / LEDS_PER_STRIP;
input %= LEDS_PER_STRIP;
int y = input / ( SCREEN_WIDTH );
int x = input % ( SCREEN_WIDTH );
if((x%2)==1) {
y = 7-y;
int output = row * LEDS_PER_STRIP
+ x * PANEL_HEIGHT
+ y;
return output;
int led_map(int x,int y) {
return led_map(y * SCREEN_WIDTH + x);
// image2data converts an image to OctoWS2811's raw data format.
// The number of vertical pixels in the image must be a multiple
// of 8. The data array must be the proper size for the image.
void image2data(PImage image, byte[] data, boolean layout) {
int offset = 0;
int x, y, mask;
int pixel;
int i=0;
for (y = 0; y < image.height; y++) {
for (x = 0; x < image.width; x++) {
pixel = image.pixels[i++];
int r = ( pixel ) >> 16;
int g = ( pixel ) >> 8;
int b = ( pixel );
offset = led_map(x,y)*3;
data[offset++] = (byte)(r & 0xfe);
data[offset++] = (byte)(g & 0xfe);
data[offset++] = (byte)(b & 0xfe);
offset=0;
data[offset++] |= (byte)0x01;
// translate the 24 bit color from RGB to the actual
// order used by the LED wiring. GRB is the most common.
int colorWiring(int c) {
int red = (c & 0xFF0000) >> 16;
int green = (c & 0x00FF00) >> 8;
int blue = (c & 0x0000FF);
red = gammatable[red];
green = gammatable[green];
blue = gammatable[blue];
return (green << 16) | (red << 8) | (blue); // GRB - most common wiring
// ask a Teensy board for its LED configuration, and set up the info for it.
void serialConfigure(String portName) {
if (numPorts >= maxPorts) {
println("too many serial ports, please increase maxPorts");
errorCount++;
return;
try {
ledSerial[numPorts] = new Serial(this, portName);
if (ledSerial[numPorts] == null) throw new NullPointerException();
ledSerial[numPorts].write('?');
} catch (Throwable e) {
println("Serial port " + portName + " does not exist or is non-functional");
errorCount++;
return;
delay(50);/*
String line = ledSerial[numPorts].readStringUntil(10);
if (line == null) {
println("Serial port " + portName + " is not responding.");
println("Is it really a Teensy 3.0 running VideoDisplay?");
errorCount++;
return;
print("port "+numPorts+": ");
String line = "32,24,0,0,0,0,0,100,100,0,0,0";
String param[] = line.split(",");
if (param.length != 12) {
println("Error: port " + portName + " did not respond to LED config query");
errorCount++;
return;
// only store the info and increase numPorts if Teensy responds properly
ledImage[numPorts] = new PImage(Integer.parseInt(param[0]), Integer.parseInt(param[1]), RGB);
ledArea[numPorts] = new Rectangle(Integer.parseInt(param[5]), Integer.parseInt(param[6]),
Integer.parseInt(param[7]), Integer.parseInt(param[8]));
ledLayout[numPorts] = (Integer.parseInt(param[5]) == 0);
numPorts++;
// draw runs every time the screen is redrawn - show the movie...
void draw() {
// show the original video
image(myMovie, 0, 80);
// then try to show what was most recently sent to the LEDs
// by displaying all the images for each port.
// compute the intended size of the entire LED array
int xsize = percentageInverse(ledImage[i].width, ledArea[i].width);
int ysize = percentageInverse(ledImage[i].height, ledArea[i].height);
// computer this image's position within it
int xloc = percentage(xsize, ledArea[i].x);
int yloc = percentage(ysize, ledArea[i].y);
// show what should appear on the LEDs
image(ledImage[i], 240 - xsize / 2 + xloc, 10 + yloc);
// respond to mouse clicks as pause/play
boolean isPlaying = true;
void mousePressed() {
if (isPlaying) {
myMovie.pause();
isPlaying = false;
myMovie.play();
isPlaying = true;
// scale a number by a percentage, from 0 to 100
int percentage(int num, int percent) {
double mult = percentageFloat(percent);
double output = num * mult;
return (int)output;
// scale a number by the inverse of a percentage, from 0 to 100
int percentageInverse(int num, int percent) {
double div = percentageFloat(percent);
double output = num / div;
return (int)output;
// convert an integer from 0 to 100 to a float percentage
// from 0.0 to 1.0. Special cases for 1/3, 1/6, 1/7, etc
// are handled automatically to fix integer rounding.
double percentageFloat(int percent) {
if (percent == 33) return 1.0 / 3.0;
if (percent == 17) return 1.0 / 6.0;
if (percent == 14) return 1.0 / 7.0;
if (percent == 13) return 1.0 / 8.0;
if (percent == 11) return 1.0 / 9.0;
if (percent == 9) return 1.0 / 11.0;
if (percent == 8) return 1.0 / 12.0;
return (double)percent / 100.0;
