formatc1702
New member
when using the teensy_loader_cli tool on OS X (just built from source), I receive the following:
Uploading via Arduino IDE + Teensyduino works fine!
What am I doing wrong? Any help would be greatly appreciated.
(And yes, I did press the reset button )
Here is some more info on my system:
Teensy 3.2
OS X 10.11.6
Teensy Loader CLI just cloned from GitHub and built from source
XCode is installed,
Specifically, I am running this code from PlatformIO, but the same error appears if I manually launch the tool.
Nonetheless:
PlatformIO-IDE 1.4.0
PlatformIO-IDE-Terminal 2.2.0
Atom 1.9.9
EDIT:
I saw the tip under System Specific Setup about changing the line in the makefile to
but it seems the line
is smarter and seems to be returning the correct path:
$ ./teensy_loader_cli -mmcu=mk20dx256 -w -s -v ~/Desktop/firmware.hex
Teensy Loader, Command Line, Version 2.0
Read "/Users/daro/Desktop/firmware.hex": 11332 bytes, 4.3% usage
Error opening HID Manager
Soft reboot is not implemented for OSX
Waiting for Teensy device...
(hint: press the reset button)
Teensy 3.2
OS X 10.11.6
XCode is installed,
$ xcrun --version
xcrun version 29
Nonetheless:
Atom 1.9.9
EDIT:
SDK ?= /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.8.sdk
SDK ?= $(shell xcrun --show-sdk-path)
$ xcrun --show-sdk-path
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.11.sdk
