Page 1 of 2 1 2 LastLast
Results 1 to 25 of 45
Thread: Try SdFat forTeensy 3.5/3.6
    243
    SdFat-beta now supports SDHC for the Teensy 3.5/3.6 on-board microSD.
    Try the TeensySdioDemo example.
    The bench, SdFormatter, and SdInfo examples can be run on Teensy 3.6 by defining the symbol USE_SDIO to be non-zero.
    Many other examples will work if you use the SdFatSdio class in place of the Sdfat class and call begin() with no parameters.
    // Replace SdFat with SdFatSdio.
    // Sdfat sd;
    SdFatSdio sd;
      // Remove parameters from begin().
      //  if (!sd.begin(chipSelect, SD_SCK_MHZ(50))) {
      if (!sd.begin()) {
        sd.initErrorHalt();
    Germany NRW
    5,679
    Great..works!
    pre-production Teensy 3.5 @ 120MHz
    size,write,read
    bytes,KB/sec,KB/sec
    512,407.27,2004.32
    1024,517.30,2579.62
    2048,1375.49,4580.52
    4096,2939.62,7467.61
    8192,4595.34,11019.66
    16384,11838.28,14052.92
    32768,14085.65,16246.76
    totalMicros  61161203
    yieldMicros  60484683
    yieldCalls   81352
    yieldMaxUsec 579390
    Done
    pre-production Teensy 3.6 @ 240MHz
    size,write,read
    bytes,KB/sec,KB/sec
    512,407.80,2071.13
    1024,530.48,2680.34
    2048,1406.73,4771.54
    4096,3474.70,7942.13
    8192,8722.41,11949.21
    16384,13145.07,15928.06
    32768,15977.66,18875.02
    totalMicros  58553159
    yieldMicros  58200508
    yieldCalls   81365
    yieldMaxUsec 20438
    Done
    Germany NRW
    5,679
    @Bill, i have a question,
    I had to run the tests above with a brand-new card (sandisk-ultra 8GB), because my old card (sandisk-ultra 16GB), which i use often for arduino-experiments or audio with teensy shows ("2048,1044.90,error: read failed").
    I've never experienced problems with the 16-GB Card. Is it possible, that the card is broken, and I've not noticed it before ?
    Or is it a bug ?
    The card was fresh-fromatted with the "official" SDFORMAT-tool.
    243
    Or is it a bug ?
    A bug is certainly possible.
    I have a 16GB and 32GB SanDisk ultra and the demo seems to run at 240 MHz. I added a SDCLK frequency print to the demo and updated GitHub.
    16 GB ultra at 240 MHz.
    size,write,read
    bytes,KB/sec,KB/sec
    512,351.74,2386.14
    1024,362.84,2908.13
    2048,931.30,5130.56
    4096,2118.74,7931.93
    8192,4379.89,12542.66
    16384,7416.31,16387.65
    32768,9031.42,18966.99
    totalMicros  74625679
    yieldMicros  74279767
    yieldCalls   80858
    yieldMaxUsec 78799
    kHzSdClk     48000
    32GB ultra at 240 MHz.
    size,write,read
    bytes,KB/sec,KB/sec
    512,402.25,1968.08
    1024,509.35,2581.77
    2048,1341.43,4619.01
    4096,3194.47,7783.48
    8192,8097.63,11792.35
    16384,12312.45,15664.71
    32768,15017.98,18703.20
    totalMicros  60579274
    yieldMicros  60237195
    yieldCalls   81452
    yieldMaxUsec 27222
    kHzSdClk     48000
    One thing to check is if the card CID look OK. Fake SanDisk cards are common.
    A PC or other device never writes a big file as many single block writes at high speed. It really punishes the card since it must copy and reprogram a big block of flash for every write. The internal flash blocks are 16K or 32K. I am running the card at 48MHz. The uSDFS library probably ran at 24 MHz.
    Run the SdIno example on the card. The result should look like this:
    Manufacturer ID: 0X3
    OEM ID: SD
    Product: SL16G
    Version: 8.0
    Serial number: 0X91203A25
    Manufacturing date: 4/2014
    cardSize: 15931.54 MB (MB = 1,000,000 bytes)
    flashEraseSize: 128 blocks
    eraseSingleBlock: true
    OCR: 0XC0FF8000
    SD Partition Table
    part,boot,type,start,length
    1,0X0,0XC,8192,31108096
    2,0X0,0X0,0,0
    3,0X0,0X0,0,0
    4,0X0,0X0,0,0
    Volume is FAT32
    blocksPerCluster: 64
    clusterCount: 485936
    freeClusters: 485677
    freeSpace: 15914.66 MB (MB = 1,000,000 bytes)
    fatStartBlock: 8790
    fatCount: 2
    blocksPerFat: 3797
    rootDirStart: 2
    dataStartBlock: 16384
    The Manufacturer ID, OEM ID, Product, and version should be the same.
    Did you format it with SD Formatter?
    There is only one standard format for an SD card. The size and position of everything is specified by the SD Association.
    Edit: Here is a Samsung 32GB Pro+. It handles small writes better.
    Samsung Pro+ 240 MHz.
    size,write,read
    bytes,KB/sec,KB/sec
    512,598.73,2204.46
    1024,1141.81,3212.32
    2048,2210.54,5370.53
    4096,3760.99,8140.06
    8192,4266.42,9312.60
    16384,7670.57,13767.16
    32768,12962.17,15782.66
    totalMicros  42140441
    yieldMicros  41846388
    yieldCalls   78584
    yieldMaxUsec 53812
    kHzSdClk     48000
    Germany NRW
    5,679
    Hi Bill, yes i used the "SD FORMATTER" tool.
    SdFat version: 20160905
     Assuming the SD is the only SPI device.
     Edit DISABLE_CHIP_SELECT to disable another device.
     Assuming the SD chip select pin is: 10
     Edit SD_CHIP_SELECT to change the SD chip select pin.
     type any character to start
     init time: 88 ms
     Card type: SDHC
     OEM ID: SD
     Product: SU16G
     Version: 8.0
     Serial number: 0XE51C7A05
     Manufacturing date: 2/2013
     OCR: 0XC0FF8000
     SD Partition Table
     1,0X0,0XC,8192,31093648
     2,0X0,0X0,0,0
     3,0X0,0X0,0,0
     4,0X0,0X0,0,0
     Volume is FAT32
     clusterCount: 485710
     freeClusters: 484128
     freeSpace: 15863.91 MB (MB = 1,000,000 bytes)
     fatStartBlock: 8794
     fatCount: 2
     blocksPerFat: 3795
     rootDirStart: 2
    5,067
    I ran on 3.5 at 120mhz Transcend 4GB card that I formated with your formater
    size,write,read
    bytes,KB/sec,KB/sec
    512,288.51,1506.30
    1024,473.70,2129.27
    2048,910.38,3737.27
    4096,1585.79,5906.54
    8192,2358.80,8297.50
    16384,3893.78,11527.31
    32768,7707.44,14256.45
    totalMicros  83588189
    yieldMicros  83091897
    yieldCalls   69354
    yieldMaxUsec 389826
    Done
    SDInfo...
    nit time: 160 ms
    Card type: SDHC
    Manufacturer ID: 0X74
    OEM ID: JE
    Product: USD
    Version: 1.0
    Serial number: 0XC21B974E
    Manufacturing date: 6/2013
    cardSize: 4035.97 MB (MB = 1,000,000 bytes)
    OCR: 0XC0FF8000
    SD Partition Table
    1,0X0,0XB,8192,7874560
    2,0X0,0X0,0,0
    3,0X0,0X0,0,0
    4,0X0,0X0,0,0
    Volume is FAT32
    clusterCount: 122912
    freeClusters: 122655
    freeSpace: 4019.16 MB (MB = 1,000,000 bytes)
    fatStartBlock: 14462
    fatCount: 2
    blocksPerFat: 961
    rootDirStart: 2
    243
    That looks like a real SanDisk card but is internally different than my 4/2014 card. Different number of blocks.
    SanDisk used a product: SU16G for a full size 5/2013 card that I have.
    Did the failure have this print out?
    size,write,read
    bytes,KB/sec,KB/sec
    512,397.21,error: read failed
    SD errorCode: 0X31,0X20002B
    The last line would help.
    Germany NRW
    5,679
    Hi Bill,
    i have different outputs. The first time, I got this:
    size,write,read bytes,KB/sec,KB/sec
     512,353.42,1165.17
     1024,638.93,2371.80
     2048,1095.24,error: read failed
     SD errorCode: 0X31,0X100021]
    now, the output is:
    size,write,read
    bytes,KB/sec,KB/sec
     512,345.43,1300.57
     1024,645.00,error: data check
    And it's slow.
    But i tried to copy a big file to the card (from PC) - this worked. And the file seems to be ok.
    Hope this helps
    5,067
    FYI I pulled out another micro SD card (Sandisk ultra 32) Ran formatter, now Teensy test. 120mhz T3.5
    Type any character to begin
    size,write,read
    bytes,KB/sec,KB/sec
    512,470.59,2055.11
    1024,1300.00,2573.00
    2048,2687.51,4620.25
    4096,4854.93,7748.13
    8192,6580.27,11362.69
    16384,7692.58,14468.85
    32768,11093.02,16577.95
    totalMicros  44313493
    yieldMicros  43742474
    yieldCalls   66930
    yieldMaxUsec 55530
    Done
    SDInfo:
    init time: 10 ms
    Card type: SDHC
    OEM ID: SD
    Product: SE32G
    Version: 8.0
    Serial number: 0XBD036D00
    Manufacturing date: 3/2015
    cardSize: 31914.98 MB (MB = 1,000,000 bytes)
    OCR: 0XC0FF8000
    SD Partition Table
    1,0X0,0XC,8192,62325760
    2,0X0,0X0,0,0
    3,0X0,0X0,0,0
    4,0X0,0X0,0,0
    Volume is FAT32
    clusterCount: 973584
    freeClusters: 973327
    freeSpace: 31893.98 MB (MB = 1,000,000 bytes)
    fatStartBlock: 9362
    fatCount: 2
    blocksPerFat: 7607
    rootDirStart: 2
    dataStartBlock: 24576
    Ran same test on T3.6 180mhz and:
    size,write,read
    bytes,KB/sec,KB/sec
    512,473.47,2029.61
    1024,1326.97,2556.80
    2048,2708.84,4700.57
    4096,4992.95,8555.75
    8192,6967.93,12123.68
    16384,8028.14,15671.06
    32768,11759.08,18317.06
    totalMicros  43642294
    yieldMicros  43337856
    yieldCalls   66941
    yieldMaxUsec 52259
    Done
    Now back to some other stuff unless you see something else you would like run.
    243
    Frank,
    The first error is a "Read Data time-out", the 0X100000 bit. The command was read-multiple blocks. The card responded that it accepted the command. There is no code during this phase, it's all done by the SDHC controller.
    I have the data timeout set to the highest possible value, 2^27 SD clocks. The manual states:
    Time-out clock frequency will be generated by dividing the base clock SDCLK value by this value.
    2^27 = 134,217,728 so with SDCLK of 48 MHz the time-out should be 2-3 seconds?
    The second case is another puzzle. Read data didn't match write data. The data is CRC protected so I suspect a bug.
    If it is a bug, it will bite more people.
    Hope I get something I can reproduce with my Teensy.
    I don't think the success with the PC helps. The PC reads/writes the file with huge multi-block transfers. That's way cards are designed to work.
    9,060
    Works for me - Thanks. Got a NEW TYQT - going to try that integrated and the SDFAT code on T_3.5 and T_3.6 - a fresh 64GB SanDisk Ultra (up to 80MB/s) card.
    TYQT is better than ever (feature wise - and getting up to speed on T_3.5 and T_3.6 - another picture on that thread
    T_3.5 at 120MHz before formatting
    init time: 8 ms
    Card type: SDXC
    OEM ID: PT
    Product: SL64G
    Version: 3.0
    Serial number: 0X45813CDA
    Manufacturing date: 4/2010
    cardSize: 62587.40 MB (MB = 1,000,000 bytes)
    OCR: 0XC0FF8000
    SD Partition Table
    1,0X0,0X7,32768,122208256
    2,0X0,0X0,0,0
    3,0X0,0X0,0,0
    4,0X0,0X0,0,0
    error:
    File System initialization failed.
    SdFormatter.ino with "F" full erase and format:
    Card Size: 62587 MB, (MB = 1,000,000 bytes)
    Erasing
    All data set to 0xff
    Erase done
    Formatting
    Blocks/Cluster: 128
    FAT32
    Format done
    And now instead of 'File System initialization failed'::
    Volume is FAT32
    blocksPerCluster: 128
    clusterCount: 954816
    freeClusters: 954815
    freeSpace: 62574.75 MB (MB = 1,000,000 bytes)
    fatStartBlock: 9656
    fatCount: 2
    blocksPerFat: 7460
    rootDirStart: 2
    Slower then Kurt's - and 5 years older - but NEW?::
    SANDISK 64GB
    size,write,read
    bytes,KB/sec,KB/sec
    512,234.90,1007.21
    1024,447.24,1856.83
    2048,836.20,3050.88
    4096,1540.81,5861.62
    8192,2863.72,9075.67
    16384,5365.59,12488.38
    32768,7069.82,15069.10
    totalMicros 94802082
    yieldMicros 94269851
    yieldCalls 65170
    yieldMaxUsec 152149
    16GB ADATA
    size,write,read
    bytes,KB/sec,KB/sec
    512,438.24,2322.88
    1024,717.08,2929.71
    2048,1604.94,4752.64
    4096,4006.46,8589.21
    8192,5526.66,11855.99
    16384,7538.85,14834.39
    32768,10189.03,16829.93
    totalMicros 52602064
    yieldMicros 51918565
    yieldCalls 81388
    yieldMaxUsec 54592
    And the ADATA SdInfo on T_3.5::
    init time: 20 ms
    Card type: SDHC
    OEM ID: SD
    Product: SL16G
    Version: 8.0
    Serial number: 0X74F3B993
    Manufacturing date: 10/2015
    OCR: 0XC0FF8000
    SD Partition Table
    2,0X0,0X0,0,0
    3,0X0,0X0,0,0
    4,0X0,0X0,0,0
    Volume is FAT32
    freeClusters: 483447
    freeSpace: 15841.59 MB (MB = 1,000,000 bytes)
    fatStartBlock: 8790
    fatCount: 2
    blocksPerFat: 3797
    rootDirStart: 2
    NOW in the T_3.6 at 180MHz first a 16GB ADATA card then the SanDisk Ultra::
    16GB ADATA
    size,write,read
    bytes,KB/sec,KB/sec
    512,356.95,1962.57
    1024,623.52,2767.51
    2048,1259.50,4965.47
    4096,3751.84,8830.67
    8192,5948.75,12874.18
    16384,8237.51,16366.39
    32768,9409.79,18374.23
    totalMicros 60736158
    yieldMicros 60317961
    yieldCalls 81376
    yieldMaxUsec 98508
    SANDISK 64GB
    size,write,read
    bytes,KB/sec,KB/sec
    512,235.11,1019.75
    1024,447.70,1863.53
    2048,854.03,3050.03
    4096,1518.74,6181.29
    8192,2891.15,9593.66
    16384,5682.16,13461.99
    32768,7555.32,16508.43
    totalMicros 94091637
    yieldMicros 94026352
    yieldCalls 65177
    yieldMaxUsec 143522
    9,060
    Reading above I'm wondering is my slow "SanDisk Ultra" - in nice retail packaging is fake? IIRC this card was new on Amazon Prime Day:
    Card type: SDXC
    OEM ID: PT
    Product: SL64G
    Version: 3.0
    The ADATA card shows this SdInfo:
    Card type: SDHC
    OEM ID: SD
    Product: SL16G
    Version: 8.0
    Germany NRW
    5,679
    Quote Originally Posted by Bill Greiman View Post
    Frank,
    Bill, would it help to send you the card ?
    btw, i made a quick'n dirty video-player with the help of your library: https://forum.pjrc.com/threads/36751...396#post114396
    Senior Member Wozzy's Avatar
    348
    Slowest Card Ever!
    Here are the results from a 2 Gb MicroSD card that Verizon sold my daughter for $24.00! when she went to pick up her phone upgrade.
    Teensy 3.6 @ 240 MHz
    TeensySdioDemo:
    size,write,read
    bytes,KB/sec,KB/sec
    512,80.21,391.42
    1024,151.88,499.64
    2048,280.97,990.58
    4096,490.71,1946.40
    8192,2523.27,3297.18
    16384,3522.41,5357.96
    32768,4538.04,7980.36
    totalMicros  270475259
    yieldMicros  270288346
    yieldCalls   80228
    yieldMaxUsec 193358
    kHzSdClk     48000
    Done
    SdInfo:
    init time: 9 ms
    Card type: SD2
    Manufacturer ID: 0X1B
    OEM ID: SM
    Product: 00000
    Version: 1.0
    Serial number: 0XAD133826
    Manufacturing date: 11/2010
    cardSize: 2002.78 MB (MB = 1,000,000 bytes)
    flashEraseSize: 64 blocks
    OCR: 0X80FF8000
    SD Partition Table
    1,0X0,0X6,129,3911551
    2,0X0,0X0,0,0
    3,0X0,0X0,0,0
    4,0X0,0X0,0,0
    Volume is FAT16
    clusterCount: 61110
    freeClusters: 60852
    freeSpace: 1994.00 MB (MB = 1,000,000 bytes)
    fatStartBlock: 130
    fatCount: 2
    blocksPerFat: 239
    rootDirStart: 608
    dataStartBlock: 640
    243
    I did some more research and both failures can happen with a bus error. The CRC for read is checked in the SDHC controller so a bus error can cause the data compare error after the CRC is checked.
    The reference manual also says a bus error can cause the time-out.
    I would like you to try the card at 180 MHz. The overclocking at 240 MHz plus a marginal card may cause the problem.
    243
    The first card is not a real SanDisk card. I have seen this CID before.
    The second card appear to be manufactured by SanDisk.
    In the future, probably in a few months, I am going to add exFAT support to SdFat. Then you won't need to format SDXC cards as FAT32. I will be very busy until mid November and then I need to tidy up SdFat before a major new development.
    2,092
    Tried SdFat on K64 and K66 with 8GB SanDisk uSD. Sdinfo good. directory listing good.
    size,write,read
    bytes,KB/sec,KB/sec
    512,264.69,1656.10
    1024,253.67,2452.38
    2048,655.89,3185.37
    4096,1498.75,5516.23
    8192,3177.63,9383.29
    16384,5595.39,13001.24
    32768,6270.75,15747.96
    totalMicros  103336131
    yieldMicros  102946810
    yieldCalls   80610
    yieldMaxUsec 32989
    kHzSdClk     45000
    Done
    Germany NRW
    5,679
    Bill, i tried the "problem"-card with 120MHz, still no success.
    Germany NRW
    5,679
    Does the sd.h wrapper work with this version sdfat ?
    I'd like to try some audio..
    243
    I am not sure what features you need.
    You should be able to run an SD.h program with SDIO on Teensy 3.5/3.6 by making the following changes.
    // replace SD.h inlclude like this.
    // #include SD.h"
    #include "SdFat.h"
    SdFatSdio SD;
      // remove chip select pin parameter from begin()
      // if (!SD.begin(CD_PIN)) {
      if (!SD.begin() {
        // handle error here.
    The main feature missing from the SDIO driver vs the SPI driver is extended multi-block read/write.
    For your failing card, hang on to it. If someone else has a similar problem, I will need to decide whether to have you send it to me or have you run some test.
    I would like to have more than one case before I spend a lot of time. I have tested about a dozen cards without a problem and quite a variety have now been tested by other users.
    Germany NRW
    5,679
    Hi Bill,
    no big problem with card. Others work, so everything is ok.
    Thank you for the hint with sd.h
    Another question: It seems to me, that your lib does not read large files ? Is that correct or my fault ?
    It stops after reading 256MB..
    Germany NRW
    5,679
    sorry!!!! it was a problem with the file..or better a problem with "processing" which created the file.
    2,092
    FYI, I have updated a K66 beta post comparing uSDFS with SdFat SDIO and with SPI SD, see
    https://forum.pjrc.com/threads/34808...l=1#post108170
    243
    The best performance for small, 512 byte, transfers on K66 is with the SdFatEX class using SPI. You must edit SdFatConfig.h to enable SdFatEX. SdFat default configuration is for the most popular Uno.
    https://forum.pjrc.com/threads/36331...6-microSD-pins
    The read and write rates are both about 3,200 KB/sec.
    I hope to do a similar SDIO driver to get higher rate for small SDIO transfers.
    For very large transfers the current SdFat will be faster than uSDFS. SdFat use high speed mode SDIO at 45 MHz on a 180 MHz K66. uSDFS is limited to 22.5 MHz.
    For small transfers the high speed mode actually seem to be slower.
    2,253
    There is no problem with setting uSDFS Baudrate to 45 MHz, simply change the number in diskio.c.
