Hi Folks,
I'm trying to write my own Arduino Library for a project that uses a Teensy + Audio Board. I don't get any error messages but there's no sound coming out of the the audio board, only some kind of digital noise.
Basically i tried to put the playSDWav Example into a library. The Example itself and my Wav files work on its own. I guess the problem comes with the copied lines from the GUI System Designer Tool. Will i have to put them in the main code or is it possible to do this in the library files?
Can somebody spot the mistake and help me get this to work? Would be great.
Thanks in advance,
steffen
NvE_AudioControl.h
NvE_AudioControl.cpp
Thanks in advance,
steffen
NvE_AudioControl.h
#ifndef NvE_AudioControl_h
#define NvE_AudioControl_h
#include "Arduino.h"
// for Audioshield
class NvE_AudioControl
public:
NvE_AudioControl(int);
void init();
void update();
void play(int);
void volume(float);
void stop();
int tracktime();
private:
int _tracks;
AudioPlaySdWav _playWav1;
AudioOutputI2S _i2s1;
//AudioConnection _patchCord1(_playWav1, 0, _i2s1, 0);
//AudioConnection _patchCord2(_playWav1, 1, _i2s1, 1);
AudioControlSGTL5000 _sgtl5000_1;
#include "NvE_AudioControl.h"
// for Audioshield
/////// AUDIO CONTROL ///////////////////
NvE_AudioControl::NvE_AudioControl(int tracks)
_tracks = tracks;
//AudioPlaySdWav _playWav1;
//AudioOutputI2S _i2s1;
//AudioControlSGTL5000 _sgtl5000_1;
// GUItool: end automatically generated code*/
void NvE_AudioControl::init()
// Audio connections require memory to work. For more
AudioMemory(60);
_sgtl5000_1.enable();
_sgtl5000_1.volume(0.8);
SPI.setMOSI(7);
SPI.setSCK(14);
if (!(SD.begin(10))) {
// stop here, but print a message repetitively
while (1) {
void NvE_AudioControl::update()
// uncomment these lines if you audio shield
// has the optional volume pot soldered
float vol = analogRead(15);
vol = vol / 1024;
_sgtl5000_1.volume(vol);
void NvE_AudioControl::play(int track_num)
switch(track_num) {
case 1:
_playWav1.play("TRACK02.WAV");
delay(20);
Serial.println("playing Track 1");
case 2:
delay(20);
Serial.println("playing Track 2");
case 3:
_playWav1.play("TRACK03.WAV");
case 4:
_playWav1.play("TRACK04.WAV");
case 5:
_playWav1.play("TRACK05.WAV");
case 6:
_playWav1.play("TRACK06.WAV");
case 7:
_playWav1.play("TRACK07.WAV");
case 8:
_playWav1.play("TRACK08.WAV");
case 9:
_playWav1.play("TRACK09.WAV");
case 10:
_playWav1.play("TRACK10.WAV");
default:
//playWav1.play("TRACK00.WAV"); //ignore unknown cases
void NvE_AudioControl::volume(float vol) // Max: 1.0 Min: 0.0
void NvE_AudioControl::stop()
if(_playWav1.isPlaying()) {
_playWav1.stop();
int NvE_AudioControl::tracktime()
return (_playWav1.positionMillis());
