Results 1 to 3 of 3
Thread: Build Issue Teensy 3.2: __AVR__ defined?
    I got a bug report that seems to indicate that __AVR__ is defined for the Teensy 3.2 builds. This define is not guarded:
    #ifdef __AVR__
      #define NEOGPS_PACKED_DATA
    A build for the Due seems to work correctly. Is __AVR__ supposed to be defined? I guess I assumed that it was the indicator for the 8-bit family of processors. This post might be related.
    Cheers,
    /dev
    26,398
    I'm testing with Arduino 1.6.11 and Teensyduino 1.30, using this:
      Serial.print("define test: ");
    #ifdef __AVR__
      Serial.print("__AVR__ ");
    #ifdef __arm__
      Serial.print("__arm__ ");
    Here's what I see in the serial monitor when I upload to a Teensy 3.2.
    With a little more information, I determined it was an out-of-date header copy in the repo that did not have the guard.
    Thanks for checking,
    /dev
