I have a teensy 3.2 and the Audio Adapter sold by pjrc. I accidentally cut through the PCB board of the teensy working on another project and pins 9 and 10 are now not connected to the Teensy chip.
I know that the Audio Adapter's SD chip select is digital pin 10. I am attempting to run the Audio Tutorial Part 2-2 which is below:
// Part 2-2: Mixers & Playing Multiple Sounds
#include <SerialFlash.h>
AudioPlaySdWav playSdWav2; //xy=93,155
AudioPlaySdWav playSdWav1; //xy=104,80
AudioMixer4 mixer1; //xy=340,144
AudioMixer4 mixer2; //xy=360,231
AudioOutputI2S i2s1; //xy=533,107
AudioConnection patchCord1(playSdWav2, 0, mixer1, 1);
AudioConnection patchCord2(playSdWav2, 1, mixer2, 1);
AudioConnection patchCord3(playSdWav1, 0, mixer1, 0);
AudioConnection patchCord4(playSdWav1, 1, mixer2, 0);
AudioConnection patchCord5(mixer1, 0, i2s1, 0);
AudioConnection patchCord6(mixer2, 0, i2s1, 1);
AudioControlSGTL5000 sgtl5000_1; //xy=492,312
#define SDCARD_CS_PIN 10
AudioMemory(8);
sgtl5000_1.enable();
sgtl5000_1.volume(0.5);
SPI.setMOSI(7);
SPI.setSCK(14);
while (1) {
pinMode(13, OUTPUT); // LED on pin 13
mixer1.gain(0, 0.5);
mixer1.gain(1, 0.5);
mixer2.gain(0, 0.5);
mixer2.gain(1, 0.5);
if (playSdWav1.isPlaying() == false) {
Serial.println("Start playing 1");
playSdWav1.play("SDTEST1.WAV");
delay(10); // wait for library to parse WAV info
if (playSdWav2.isPlaying() == false) {
Serial.println("Start playing 2");
playSdWav2.play("SDTEST4.WAV");
And of course I get the following error when I run this:
"Unable to access the SD card"
Which I am assuming is being cause by the fact that I sawed off the connection of the Teensy digital pin 10 to the rest of the board. Is this a correct assumption?
Also, is there any way around this that you can see. Can I connect, say, digital pin 21 (which is also a Chip select pin) to the SD chip select pin on the Audio Board and read the card this way?
Thank you
AudioMemory(8);
SPI.setMOSI(7);
SPI.setSCK(14);
while (1) {
Thank you
