KurtE
Senior Member+
As I mentioned, Thought it was time to start assembling the main board of this thread.
I probably should have done this more in stages, as to not waste too many parts if some basic things were not working, but...
I did assemble most/all of the surface mount parts, first, and got enough on it, such that I could plug in 12v, to make sure nothing was smoking, before I installed the Teensy. Here is a picture at that point:
Nothing was smoking or warm, also had +5v at the appropriate pins I checked, so I continued to assemble the board, and added the Teensy and then verified that I could upload Blink... so still looking promising, so I continued to assemble the rest of the board (more or less).
Now there are lots of stuff I need to start testing. I have a test program for the earlier T3.2 based board similar to this, which I will need to adapt and see what works and what does not...
