I have problems sending a proper Timestamp from the Teensy to the network with OSC.
This is a confusing problem, because timestamps in TimeLib.h and OSCTiming.h have wildly different layouts. While TimeLib works with unix timestamps, osc has a fixed-point 8byte format, starting at epoch 1900.
My steps so far:
seems to me like oscTime() calculates it's time solely from elapsed millis(), and completely ignores the system clock. see code.
i am not sure on how to proceed. should I manually fill up an osctime struct from the data i retrieve by the methods in TimeLib? I guess that might be possible.
Would it be a good idea to have conversion like that in latchOscTime?
My steps so far:
- equipping a Teensy 3.2 with a quartz - success
- making sure I can set the time by OSC command - partial success only unix timestamps so far, as seen in TimeTeensy3 example
- reading out the time with oscTime() again - fail...
- attaching it to the osc bundle success
- sending it over the wire success
* Teensy Code for 3.2
Read out some buttons, make an OSC bundle and send it over UDP.
Receive some pwm values for some LED.
Code contains stuff for debouncing the buttons.
// use the quarz
#include <TimeLib.h>
// retrieve mac from teensy
#include "T3Mac/T3Mac.h"
#include <Ethernet.h>
#include <EthernetUdp.h>
// pins 9, 10, 11, 12, 13 are used by ethernet
// pin 4 might be used by sd card
#include <OSCBundle.h>
#include <OSCData.h>
#include <OSCTiming.h>
#include <Bounce2.h>
const char MyName[] = "GetHim_A";
IPAddress ip(192, 168, 2, 107); // my IP
IPAddress outIp(192, 168, 2, 108); // target server
const unsigned int localPort = 9999; // local port to listen on
const unsigned int outPort = 9998;
unsigned int buttonPin[] = {5, 6, 7, 8};
unsigned int ledPin[] = {20, 21, 22, 23}; // A6 - A9 are pwm
EthernetUDP Udp;
Bounce buttons[4];
elapsedMillis watch;
// set the Time library to use Teensy 3.2's RTC to keep time
// while (!Serial); // Wait for Arduino Serial Monitor to open
// populates the mac variable
read_mac();
print_mac();
if (timeStatus()!= timeSet) {
Serial.println("Unable to sync with the RTC");
Serial.println("RTC has set the system time");
Ethernet.begin(mac,ip);
Udp.begin(localPort);
Serial.println(Ethernet.localIP());
for (int i=0;i<4;i++) pinMode(buttonPin[i], INPUT_PULLUP);
for (int i=0;i<4;i++) pinMode(ledPin[i], OUTPUT);
for (int i=0;i<4;i++) buttons[i] = Bounce(buttonPin[i], 10); // 10ms debounce
time_t getTeensy3Time()
return Teensy3Clock.get();
void updateLed(OSCMessage &mes){
for (int i = 0; i < 4; i++){
int signal = mes.getInt(i);
analogWrite(ledPin[i], signal);
void updateClock(OSCMessage &mes) {
Serial.println("attempting to update clock");
time_t signal = mes.getInt(0);
Serial.println(signal);
Teensy3Clock.set(signal); // set the RTC
setTime(signal);
timeToSerial();
void printTime(OSCMessage &mes) {
timeToSerial();
void timeToSerial() {
// digital clock display of the time
Serial.print(hour());
printDigits(minute());
printDigits(second());
Serial.print(" ");
Serial.print(day());
Serial.print(" ");
Serial.print(month());
Serial.print(" ");
Serial.println(year());
void printDigits(int digits){
// utility function for digital clock display: prints preceding colon and leading 0
Serial.print(":");
if(digits < 10)
Serial.print('0');
Serial.print(digits);
void loop(){
OSCBundle bundle;
// receive
int size = Udp.parsePacket();
if (size > 0) {
while (size--) {
bundle.fill(Udp.read());
if (!bundle.hasError()) {
bundle.dispatch("/led", updateLed);
bundle.dispatch("/unixtime", updateClock);
bundle.dispatch("/printtime", printTime);
OSCErrorCode error = bundle.getError();
Serial.print("error: ");
Serial.println(error);
bundle.empty();
for (int i=0;i<4;i++) {
// buttons[i].update();
// int pressed = 1 - buttons[i].read();
int pressed = 1 - digitalRead(buttonPin[i]);
String addressString = String("/").concat(MyName).concat("/b").concat(i);
char address[addressString.length()+1];
addressString.toCharArray(address, addressString.length()+1);
bundle.add(address).add(pressed);
bundle.setTimetag(oscTime());
String addressString = String("/").concat(MyName).concat("/millis");
bundle.add(address).add((long int)millis());
// bundle.add(address).add(oscTime());
Udp.beginPacket(outIp, outPort);
bundle.send(Udp); // send the bytes to the SLIP stream
Udp.endPacket(); // mark the end of the OSC Packet
bundle.empty(); // empty the bundle to free room for a new one
