I couldn't find anyone mentioning this, but while troubleshooting a temperamental USB Serial connection (missing output in my serial console) I found there are some characters waiting to be read every time Teensy connects..
I'm not expecting the "M501<enter>" bytes when the Teensy connects to the Mac!
Has anyone else noticed something like this. Any suggestions for tracking down and removing what's causing it??
This is the code I use in setup() to produce the output shown above:
My serial terminal is minicom, installed via homebrew.
And the connection is made with:
Any other details relevant to the troubleshooting?
Slurped serial bytes.
0x4D 0x35 0x30 0x31 0xA
M501
Connected USB.
19200
TAB => showPorts()
ENTER => setupPorts()
SPACE => readEprom()
Serial.begin(1); // USB, communication to PC or Mac
setupLED();
delay(750);
while (!Serial.availableForWrite()) {
analogWrite(LED_RED, 180);
analogWrite(LED_GREEN, 50);
size_t len = 0;
if (Serial.available()) {
len = Serial.readBytes(usb_chars, 64);
Serial.write(ERASE_DISPLAY, 4);
if (len > 0) {
Serial.println("Slurped serial bytes.");
for (size_t i = 0; i < len; i++) {
Serial.print("0x");
Serial.print(usb_chars[i], HEX);
Serial.print(' ');
Serial.print(usb_chars[i]);
Serial.println("Connected USB.");
Serial.println(Serial.baud());
// Enable the EPROM output
pinMode(EPROM_ENABLE, OUTPUT);
digitalWrite(EPROM_ENABLE, HIGH);
delay(50);
digitalWrite(EPROM_ENABLE, LOW);
delay(200);
analogWrite(LED_GREEN, 2);
Serial.println("TAB => showPorts()");
Serial.println("ENTER => setupPorts()");
Serial.println("SPACE => readEprom()");
// For completeness..
// PWM pins for RGB LED
#define LED_RED 25
#define LED_GREEN 3
#define LED_BLUE 32
void setupLED() {
// Setup RGB LED on PWM
pinMode(LED_RED, OUTPUT);
pinMode(LED_GREEN, OUTPUT);
pinMode(LED_BLUE, OUTPUT);
analogWrite(LED_RED, 0);
analogWrite(LED_GREEN, 0);
analogWrite(LED_BLUE, 0);
$ brew install minicom
$ minicom -D /dev/cu.usbmodem1244611 -b 19200 -8 -c on -a on
