Results 1 to 2 of 2
Thread: Using IntervalTimer in Arduino Library
    Senior Member brtaylor's Avatar
    Mar 2016
    Portland, OR
    536
    I'm sure I need more coffee, but...I'm trying to add an interval timer within an arduino library, specifically to emulate 2 stop bits on Teensy 3.1/3.2 for SBUS.
    I have the interrupt function defined as well as the IntervalTimer object as private members of the SBUS class.
    class SBUS{
    	public:
        	        void write(int16_t* channels);
      	private:
      		void sendByte(void);
      		IntervalTimer serialTimer;
    And I have the sendByte function defined as:
    void SBUS::sendByte(void) {
    	if(_sendIndex < 25) {
    		_port->write(_packet[_sendIndex]);
    		_sendIndex++;
    	else{
    		serialTimer.end();
    With it called like:
    serialTimer.begin(sendByte,120);
    But I'm getting a compile error about no matching function call with sendByte being overloaded.
    error: no matching function for call to 'IntervalTimer::begin(<unresolved overloaded function type>, int)'
    Any hints? Thanks much!
    Germany NRW
    5,679
    Yes, try a global function instead. It will not work with an object (only with dirty tricks, like using a pointer to your function, as far as i know.)
