Paul, I am using Teensy 3.2 and your new Pro Shield and using Teensy internal clock with added crystal and coin battery attached to Vbat and ground. I am using Teensy TimeTeensy3 and Lib #include <Time.h>
#include <TimeLib.h>. Clock works find with Teensy powered on but when power is turn off RTC is not keeping time it recalls last time set? If I test Teensy not connected to Pro Shield and power off and power back up it picks up the correct time. My question is with Pro Shield connect did a pin change occur?
Thanks,
Manny
Thanks,
Manny
