Arduino: 1.6.11 (Mac OS X), TD: 1.30, Board: "Teensy 3.2 / 3.1, Serial, 96 MHz optimize speed (overclock), US English"
/private/var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/AppTranslocation/484F4DA0-B613-4EB5-8014-FEBEB492D12F/d/Arduino with TD1.30.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /private/var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/AppTranslocation/484F4DA0-B613-4EB5-8014-FEBEB492D12F/d/Arduino with TD1.30.app/Contents/Java/hardware -tools /private/var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/AppTranslocation/484F4DA0-B613-4EB5-8014-FEBEB492D12F/d/Arduino with TD1.30.app/Contents/Java/tools-builder -tools /private/var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/AppTranslocation/484F4DA0-B613-4EB5-8014-FEBEB492D12F/d/Arduino with TD1.30.app/Contents/Java/hardware/tools/avr -built-in-libraries /private/var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/AppTranslocation/484F4DA0-B613-4EB5-8014-FEBEB492D12F/d/Arduino with TD1.30.app/Contents/Java/libraries -libraries /Users/dean/Documents/Arduino/libraries -fqbn=teensy:avr:teensy31:usb=serial,speed=96opt,keys=en-us -ide-version=10611 -build-path /var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/buildf5ef3cb51e7f9b1337211a353cc29e3c.tmp -warnings=none -verbose /var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/untitled791152988.tmp/sketch_sep18a/sketch_sep18a.ino
/private/var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/AppTranslocation/484F4DA0-B613-4EB5-8014-FEBEB492D12F/d/Arduino with TD1.30.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /private/var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/AppTranslocation/484F4DA0-B613-4EB5-8014-FEBEB492D12F/d/Arduino with TD1.30.app/Contents/Java/hardware -tools /private/var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/AppTranslocation/484F4DA0-B613-4EB5-8014-FEBEB492D12F/d/Arduino with TD1.30.app/Contents/Java/tools-builder -tools /private/var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/AppTranslocation/484F4DA0-B613-4EB5-8014-FEBEB492D12F/d/Arduino with TD1.30.app/Contents/Java/hardware/tools/avr -built-in-libraries /private/var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/AppTranslocation/484F4DA0-B613-4EB5-8014-FEBEB492D12F/d/Arduino with TD1.30.app/Contents/Java/libraries -libraries /Users/dean/Documents/Arduino/libraries -fqbn=teensy:avr:teensy31:usb=serial,speed=96opt,keys=en-us -ide-version=10611 -build-path /var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/buildf5ef3cb51e7f9b1337211a353cc29e3c.tmp -warnings=none -verbose /var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/untitled791152988.tmp/sketch_sep18a/sketch_sep18a.ino
Using board 'teensy31' from platform in folder: /private/var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/AppTranslocation/484F4DA0-B613-4EB5-8014-FEBEB492D12F/d/Arduino with TD1.30.app/Contents/Java/hardware/teensy/avr
Using core 'teensy3' from platform in folder: /private/var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/AppTranslocation/484F4DA0-B613-4EB5-8014-FEBEB492D12F/d/Arduino with TD1.30.app/Contents/Java/hardware/teensy/avr
Detecting libraries used...
"/private/var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/AppTranslocation/484F4DA0-B613-4EB5-8014-FEBEB492D12F/d/Arduino with TD1.30.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10611 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/private/var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/AppTranslocation/484F4DA0-B613-4EB5-8014-FEBEB492D12F/d/Arduino with TD1.30.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/buildf5ef3cb51e7f9b1337211a353cc29e3c.tmp/sketch/sketch_sep18a.ino.cpp" -o "/dev/null"
Generating function prototypes...
"/private/var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/AppTranslocation/484F4DA0-B613-4EB5-8014-FEBEB492D12F/d/Arduino with TD1.30.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10611 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/private/var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/AppTranslocation/484F4DA0-B613-4EB5-8014-FEBEB492D12F/d/Arduino with TD1.30.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/buildf5ef3cb51e7f9b1337211a353cc29e3c.tmp/sketch/sketch_sep18a.ino.cpp" -o "/var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/buildf5ef3cb51e7f9b1337211a353cc29e3c.tmp/preproc/ctags_target_for_gcc_minus_e.cpp"
"/private/var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/AppTranslocation/484F4DA0-B613-4EB5-8014-FEBEB492D12F/d/Arduino with TD1.30.app/Contents/Java/tools-builder/ctags/5.8-arduino10/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "/var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/buildf5ef3cb51e7f9b1337211a353cc29e3c.tmp/preproc/ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"/private/var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/AppTranslocation/484F4DA0-B613-4EB5-8014-FEBEB492D12F/d/Arduino with TD1.30.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10611 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/private/var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/AppTranslocation/484F4DA0-B613-4EB5-8014-FEBEB492D12F/d/Arduino with TD1.30.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/buildf5ef3cb51e7f9b1337211a353cc29e3c.tmp/sketch/sketch_sep18a.ino.cpp" -o "/var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/buildf5ef3cb51e7f9b1337211a353cc29e3c.tmp/sketch/sketch_sep18a.ino.cpp.o"
Compiling libraries...
Compiling core...
"/private/var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/AppTranslocation/484F4DA0-B613-4EB5-8014-FEBEB492D12F/d/Arduino with TD1.30.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10611 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/private/var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/AppTranslocation/484F4DA0-B613-4EB5-8014-FEBEB492D12F/d/Arduino with TD1.30.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/private/var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/AppTranslocation/484F4DA0-B613-4EB5-8014-FEBEB492D12F/d/Arduino with TD1.30.app/Contents/Java/hardware/teensy/avr/cores/teensy3/memcpy-armv7m.S" -o "/var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/buildf5ef3cb51e7f9b1337211a353cc29e3c.tmp/core/memcpy-armv7m.S.o"
failed MSpanList_Insert 0x3120e8 0x2fbcf2b7ba0 0x0
fatal error: MSpanList_Insert
runtime stack:
runtime.MSpanList_Insert(0x2cadd0, 0x3120e8)
/usr/local/go/src/runtime/mheap.c:692 +0x8f
runtime.MHeap_Free(0x2cad60, 0x3120e8, 0xc200000000)
/usr/local/go/src/runtime/mheap.c:500 +0x5b
runtime.MCentral_FreeSpan(0x2d3df8, 0x3120e8, 0x1, 0xc208122000, 0xc208122000, 0xf900, 0x64)
/usr/local/go/src/runtime/mcentral.c:181 +0x1bb
runtime.MSpan_Sweep(0x3120e8, 0x4900000000, 0xc200000001)
/usr/local/go/src/runtime/mgc0.c:1099 +0x477
goroutine 3 [running]:
runtime.switchtoM()
/usr/local/go/src/runtime/asm_amd64.s:198 fp=0xc20801dfa8 sp=0xc20801dfa0
runtime.gosweepone(0x0)
/usr/local/go/src/runtime/mgc0.c:1168 +0x1e fp=0xc20801dfc0 sp=0xc20801dfa8
runtime.bgsweep()
/usr/local/go/src/runtime/mgc0.go:85 +0x36 fp=0xc20801dfe0 sp=0xc20801dfc0
runtime.goexit()
/usr/local/go/src/runtime/asm_amd64.s:2232 +0x1 fp=0xc20801dfe8 sp=0xc20801dfe0
created by gc
/usr/local/go/src/runtime/mgc0.c:1386
goroutine 1 [syscall]:
syscall.Syscall6(0x7, 0xd34, 0xc208178e64, 0x0, 0xc208191440, 0x0, 0x0, 0x30c000, 0x6aa1, 0xc2081940e0)
/usr/local/go/src/syscall/asm_darwin_amd64.s:44 +0x5
syscall.wait4(0xd34, 0xc208178e64, 0x0, 0xc208191440, 0x90, 0x0, 0x0)
/usr/local/go/src/syscall/zsyscall_darwin_amd64.go:32 +0x79
syscall.Wait4(0xd34, 0xc208178eac, 0x0, 0xc208191440, 0x0, 0x0, 0x0)
/usr/local/go/src/syscall/syscall_bsd.go:162 +0x60
os.(*Process).wait(0xc20808f8c0, 0x0, 0x0, 0x0)
/usr/local/go/src/os/exec_unix.go:22 +0x103
os.(*Process).Wait(0xc20808f8c0, 0xc20811c600, 0x0, 0x0)
/usr/local/go/src/os/doc.go:45 +0x3a
os/exec.(*Cmd).Wait(0xc20800b040, 0x0, 0x0)
/usr/local/go/src/os/exec/exec.go:364 +0x23c
os/exec.(*Cmd).Run(0xc20800b040, 0x0, 0x0)
/usr/local/go/src/os/exec/exec.go:246 +0x71
arduino.cc/builder/builder_utils.ExecRecipe(0xc2082f22d0, 0x1f2550, 0x12, 0x10100, 0x31dd90, 0x2c49b0, 0x0, 0x0, 0x0, 0x0, ...)
/Users/jenkins/jenkins/workspace/arduino-builder-macosx/src/arduino.cc/builder/builder_utils/utils.go:298 +0x1f7
arduino.cc/builder/builder_utils.compileFileWithRecipe(0xc20813e540, 0xb8, 0xc208155110, 0xc8, 0xc2080381e0, 0x5f, 0xc2081065d0, 0xc2082ea200, 0x1, 0x1, ...)
/Users/jenkins/jenkins/workspace/arduino-builder-macosx/src/arduino.cc/builder/builder_utils/utils.go:153 +0x86c
arduino.cc/builder/builder_utils.compileFilesWithRecipe(0xc208179610, 0x0, 0x0, 0xc20813e540, 0xb8, 0xc2082e82e0, 0x2, 0x2, 0xc2080381e0, 0x5f, ...)
/Users/jenkins/jenkins/workspace/arduino-builder-macosx/src/arduino.cc/builder/builder_utils/utils.go:121 +0x1c3
arduino.cc/builder/builder_utils.compileFilesWithExtensionWithRecipe(0xc208179610, 0x0, 0x0, 0xc20813e540, 0xb8, 0xc2082fc001, 0xc2080381e0, 0x5f, 0xc2081065d0, 0xc2082ea200, ...)
/Users/jenkins/jenkins/workspace/arduino-builder-macosx/src/arduino.cc/builder/builder_utils/utils.go:88 +0x248
arduino.cc/builder/builder_utils.CompileFiles(0xc208179610, 0x0, 0x0, 0xc20813e540, 0xb8, 0x1, 0xc2080381e0, 0x5f, 0xc2081065d0, 0xc2082ea200, ...)
/Users/jenkins/jenkins/workspace/arduino-builder-macosx/src/arduino.cc/builder/builder_utils/utils.go:68 +0x175
arduino.cc/builder/phases.compileCore(0xc2080381e0, 0x5f, 0xc2081065d0, 0x1, 0x7fff5fbffd1f, 0x4, 0x31dd90, 0x2c49b0, 0x0, 0x0, ...)
/Users/jenkins/jenkins/workspace/arduino-builder-macosx/src/arduino.cc/builder/phases/core_builder.go:87 +0x66a
arduino.cc/builder/phases.(*CoreBuilder).Run(0x2c49b0, 0xc208066000, 0x0, 0x0)
/Users/jenkins/jenkins/workspace/arduino-builder-macosx/src/arduino.cc/builder/phases/core_builder.go:55 +0x20f
arduino.cc/builder.runCommands(0xc208066000, 0xc208179a98, 0x22, 0x22, 0x1, 0x0, 0x0)
/Users/jenkins/jenkins/workspace/arduino-builder-macosx/src/arduino.cc/builder/builder.go:189 +0x139
arduino.cc/builder.(*Builder).Run(0xc208179ce0, 0xc208066000, 0x0, 0x0)
/Users/jenkins/jenkins/workspace/arduino-builder-macosx/src/arduino.cc/builder/builder.go:124 +0x1227
arduino.cc/builder.RunBuilder(0xc208066000, 0x0, 0x0)
/Users/jenkins/jenkins/workspace/arduino-builder-macosx/src/arduino.cc/builder/builder.go:220 +0x49
main.main()
/Users/jenkins/jenkins/workspace/arduino-builder-macosx/src/arduino.cc/arduino-builder/main.go:316 +0x171b
/private/var/folders/0q/431m749x0gs0_tgtq15rjxl80000gn/T/AppTranslocation/484F4DA0-B613-4EB5-8014-FEBEB492D12F/d/Arduino with TD1.30.app/Contents/Java/arduino-builder returned 2
Error compiling for board Teensy 3.2 / 3.1.
