Results 1 to 3 of 3
Thread: Audio designer SGTL5000 autoVolumeControl function: error in code- Solution found
    Senior Member bmillier's Avatar
    Apr 2016
    Halifax, N.S. Canada
    187
    Teensyduino vers: 1.29
    The SGTL5000 AutoVolumeControl function does not work as described. There are 3 incorrect lines in the code which result in the Threshold (16-bit), Attack(12-bit) and Decay(12-bit) registers of the SCTL5000 being loaded incorrectly.
    In the file "control_sgtl5000.cpp" the following 3 lines
    Line#
    844 uint8_t thresh = (pow(10, threshold / 20)*0.636)*pow(2, 15);
    845 uint8_t att=(1-pow(10,-(attack/(20*44100))))*pow(2,19);
    846 uint8_t dec=(1-pow(10,-(decay/(20*44100))))*pow(2,23);
    should be replaced with
    uint16_t thresh = (pow(10, threshold / 20)*0.636)*pow(2, 15);
    uint16_t att=(1-pow(10,-(attack/(20*44100))))*pow(2,19);
    uint16_t dec=(1-pow(10,-(decay/(20*44100))))*pow(2,23);
    This loads the registers with the proper 16, 12-bit values, and when I tested it out on the Audioshield, the AVC now works properly.
    3,674
    Quote Originally Posted by bmillier View Post
    Line#
    Though for the 3.5/3.6, perhaps powf should be used:
    	uint16_t thresh = (powf(10f, threshold / 20.0f)*0.636f)*powf(2.0f, 15.0f);
    	uint16_t att=(1-powf(10f,-(attack/(20.0f*44100.0f))))*powf(2.0f,19.0f);
    	uint16_t dec=(1-powf(10.0f,-(decay/(20.f*44100.0f))))*pow(2.0f,23.0f);
    The reason is powf is done in single precision floating point, which the machine supports directly, while pow is done in double precision, which is simulated on the Teensys.
    Apr 2016
    187
    I expect you are right. I have a kickstarter T3.5 coming whenever they get shipped, but for now I am still using T3.2 & TD v1.29 and the big problem is the improperly cast variables, as I mentioned.
