Hi Guys,
New to the world of custom controllers. Using teensy 3.2
Trying to build and code a simply 8 linear potentiometer midi controller.
Currently using a custom code however doesn't seem to be the absolute correct thing for my needs. Wondering if anyone can help.
8 Faders
A0 - A7 (analog inputs on teensy 3.2)
Need to be able to customise each input for a different CC value. (Eg A0 = CC1, A1 = CC7) Etc. Customisable. (Change midi channel etc)
Also, using 100 mm linear potentiometers. The current range only works till half of the length of the fader. Need to be able to utilise the full range of the 100 mm. (1 - 127 = 100 mm of the fader) if that makes sense.
Please help anyone. Trying to read and learn code, and got no idea.
Thanks in advance.
Corey
8 Faders
Thanks in advance.
Corey
