Greetings to all,
I am developing a MIDI driver and use Arduino Serial Plotter for debugging purposes. I compile the sketch with Arduino 1.6.7 + Teensyduino 1.27 in “USB MIDI” mode and upload to a Teensy 3.2 board.
It worked until a few days ago, but now the Serial Plotter is unable to receive the serial printed values. The Serial Monitor still receives the values correctly and if I compile in “USB Serial” mode both Serial Monitor and Serial Plotter work properly (but I can’t use the usbmidi functions)
I tried reinstalling Arduino 1.6.7 + Teensyduino 1.27 and the most recent Arduino 1.6.11 + Teensyduino 1.30, over Windows 7 an well as over Windows XP but the problem persists.
I tested unsuccessfully the USB modes “MIDI”, “Serial + MIDI”, “Serial + MIDI + Audio”
It seems as if the Arduino Serial Monitor is able to recognize the “emulated serial mode” and receive through it but the Serial Plotter insists on receiving through a nonexistent COM
It worked until a few days ago and I am not aware of having changed anything. The problem is the same with many different sketches which previously functioned well.
Can anyone give me a clue about what might be happening?
The code snippet I use for testing:
void setup(){
elapsedMillis crono = 0;
int t = 0;
while(!Serial); // Wait for Serial
for(;;){
while(crono < 40); // Wait 40 ms
crono = 0;
Serial.println(t++);
if(t > 300) t = 0;
void loop(){
