Are there any objections,to use the RESET pin of Teensy 3.5 / Teensy 3.6 as output to reset external chips (for example, for ILI9341)?
- For an "automatic" reset when re-programming the Teensy.
In the Adafruit forum, there was a discussion that tying the reset pin to the OLED reset did not work well with some microprocessors. In particular, I saw it when I had a Teensy in the Adafruit Teensy to Feather adapter and using the 128x32 OLED feather wing (the Teensy->Feather adapter attaches the program pin to the feather reset pin). A lot of times it would just produce snow on the OLED, though there were times when it seemed to work. Eventually, I just clipped the reset (program) pin in the OLED wing and used an external reset pin (https://forums.adafruit.com/viewtopic.php?f=57&t=100042)
