// RawHardwareTest - Check if a SPI Flash chip is compatible
// with SerialFlash by performing many read and write tests
// to its memory.
// The chip should be fully erased before running this test.
// Use the EraseEverything to do a (slow) full chip erase.
// Normally you should NOT access the flash memory directly,
// as this test program does. You should create files and
// read and write the files. File creation allocates space
// with program & erase boundaries within the chip, to allow
// reading from any other files while a file is busy writing
// or erasing (if created as erasable).
// If you discover an incompatible chip, please report it here:
// https://github.com/PaulStoffregen/SerialFlash/issues
// You MUST post the complete output of this program, and
// the exact part number and manufacturer of the chip.
const int FlashChipSelect = 9; // digital pin for flash chip CS pin
SerialFlashFile file;
const unsigned long testIncrement = 4096;
//uncomment these if using Teensy audio shield
SPI.setSCK(13); // Audio shield has SCK on pin 14
SPI.setMOSI(11); // Audio shield has MOSI on pin 7
SPI.setMISO(12);
//uncomment these if you have other SPI chips connected
//to keep them disabled while using only SerialFlash
//pinMode(4, INPUT_PULLUP);
//pinMode(10, INPUT_PULLUP);
while (!Serial) ;
Serial.println("Raw SerialFlash Hardware Test");
SerialFlash.begin(FlashChipSelect);
if (test()) {
Serial.println("All Tests Passed :-)");
Serial.println("Test data was written to your chip. You must run");
Serial.println("EraseEverything before using this chip for files.");
Serial.println("Tests Failed :{");
Serial.println("The flash chip may be left in an improper state.");
Serial.println("You might need to power cycle to return to normal.");
bool test() {
unsigned char buf[256], sig[256], buf2[8];
unsigned long address, count, chipsize, blocksize;
unsigned long usec;
bool first;
// Read the chip identification
Serial.println("Read Chip Identification:");
SerialFlash.readID(buf);
Serial.print(" JEDEC ID: ");
Serial.print(buf[0], HEX);
Serial.print(" ");
Serial.print(buf[1], HEX);
Serial.print(" ");
Serial.println(buf[2], HEX);
Serial.print(" Part Nummber: ");
Serial.println(id2chip(buf));
Serial.print(" Memory Size: ");
chipsize = SerialFlash.capacity(buf);
Serial.print(chipsize);
Serial.println(" bytes");
if (chipsize == 0) return false;
Serial.print(" Block Size: ");
blocksize = SerialFlash.blockSize();
Serial.print(blocksize);
// Read the entire chip. Every test location must be
// erased, or have a previously tested signature
Serial.println("Reading Chip...");
memset(buf, 0, sizeof(buf));
memset(sig, 0, sizeof(sig));
memset(buf2, 0, sizeof(buf2));
address = 0;
count = 0;
first = true;
while (address < chipsize) {
SerialFlash.read(address, buf, 8);
//Serial.print(" addr = ");
//Serial.print(address, HEX);
//Serial.print(", data = ");
//printbuf(buf, 8);
create_signature(address, sig);
if (is_erased(buf, 8) == false) {
if (equal_signatures(buf, sig) == false) {
Serial.print(" Previous data found at address ");
Serial.println(address);
Serial.println(" You must fully erase the chip before this test");
Serial.print(" found this: ");
printbuf(buf, 8);
Serial.print(" correct: ");
printbuf(sig, 8);
return false;
count = count + 1; // number of blank signatures
if (first) {
address = address + (testIncrement - 8);
first = false;
address = address + 8;
first = true;
// Write any signatures that were blank on the original check
if (count > 0) {
Serial.print("Writing ");
Serial.print(count);
Serial.println(" signatures");
address = 0;
first = true;
if (is_erased(buf, 8)) {
//Serial.printf("write %08X: data: ", address);
//printbuf(sig, 8);
SerialFlash.write(address, sig, 8);
while (!SerialFlash.ready()) ; // wait
Serial.print(" error writing signature at ");
Serial.print(" Read this: ");
printbuf(buf, 8);
Serial.print(" Expected: ");
printbuf(sig, 8);
return false;
if (first) {
first = false;
first = true;
Serial.println(" all signatures present from prior tests");
// Read all the signatures again, just to be sure
// checks prior writing didn't corrupt any other data
Serial.println("Double Checking All Signatures:");
count = 0;
address = 0;
first = true;
Serial.print(" error in signature at ");
printbuf(buf, 8);
printbuf(sig, 8);
return false;
count = count + 1;
if (first) {
first = false;
first = true;
Serial.print(" all ");
Serial.println(" signatures read ok");
// Read pairs of adjacent signatures
// check read works across boundaries
Serial.println("Checking Signature Pairs");
count = 0;
address = testIncrement - 8;
first = true;
while (address < chipsize - 8) {
SerialFlash.read(address, buf, 16);
create_signature(address + 8, sig + 8);
if (memcmp(buf, sig, 16) != 0) {
Serial.print(" error in signature pair at ");
printbuf(buf, 16);
printbuf(sig, 16);
return false;
count = count + 1;
address = address + testIncrement;
Serial.println(" signature pairs read ok");
// Write data and read while write in progress
Serial.println("Checking Read-While-Write (Program Suspend)");
address = 256;
while (address < chipsize) { // find a blank space
SerialFlash.read(address, buf, 256);
if (is_erased(buf, 256)) break;
address = address + 256;
if (address >= chipsize) {
Serial.println(" error, unable to find any blank space!");
return false;
for (int i=0; i < 256; i += 8) {
create_signature(address + i, sig + i);
Serial.print(" write 256 bytes at ");
Serial.flush();
SerialFlash.write(address, sig, 256);
usec = micros();
if (SerialFlash.ready()) {
Serial.println(" error, chip did not become busy after write");
return false;
SerialFlash.read(0, buf2, 8); // read while busy writing
usec = micros() - usec;
Serial.print(" write time was ");
Serial.print(usec);
Serial.println(" microseconds.");
if (memcmp(buf, sig, 256) != 0) {
Serial.println(" error writing to flash");
printbuf(buf, 256);
printbuf(sig, 256);
return false;
create_signature(0, sig);
if (memcmp(buf2, sig, 8) != 0) {
Serial.println(" error, incorrect read while writing");
printbuf(buf2, 256);
printbuf(sig, 256);
return false;
Serial.print(" read-while-writing: ");
printbuf(buf2, 8);
Serial.println(" test passed, good read while writing");
// Erase a block and read while erase in progress
if (chipsize >= 262144 + blocksize + testIncrement) {
Serial.println("Checking Read-While-Erase (Erase Suspend)");
SerialFlash.eraseBlock(262144);
usec = micros();
delayMicroseconds(50);
Serial.println(" error, chip did not become busy after erase");
return false;
Serial.print(" erase time was ");
Serial.print(usec);
// read all signatures, check ones in this block got
// erased, and all the others are still intact
address = 0;
first = true;
if (address >= 262144 && address < 262144 + blocksize) {
Serial.print(" error in erasing at ");
printbuf(buf, 8);
return false;
printbuf(buf, 8);
printbuf(sig, 8);
return false;
if (first) {
first = false;
first = true;
Serial.print(" erase correctly erased ");
// now check if the data we read during erase is good
Serial.println(" error, incorrect read while erasing");
printbuf(sig, 256);
return false;
Serial.print(" read-while-erasing: ");
printbuf(buf2, 8);
Serial.println(" test passed, good read while erasing");
Serial.println("Skip Read-While-Erase, this chip is too small");
return true;
// do nothing after the test
const char * id2chip(const unsigned char *id)
if (id[0] == 0xEF) {
// Winbond
if (id[1] == 0x40) {
if (id[2] == 0x14) return "W25Q80BV";
if (id[2] == 0x17) return "W25Q64FV";
if (id[2] == 0x18) return "W25Q128FV";
if (id[2] == 0x19) return "W25Q256FV";
if (id[0] == 0x01) {
// Spansion
if (id[1] == 0x02) {
if (id[2] == 0x16) return "S25FL064A";
if (id[2] == 0x19) return "S25FL256S";
if (id[2] == 0x20) return "S25FL512S";
if (id[1] == 0x20) {
if (id[2] == 0x18) return "S25FL127S";
if (id[0] == 0xC2) {
// Macronix
if (id[2] == 0x18) return "MX25L12805D";
if (id[0] == 0x20) {
// Micron
if (id[1] == 0xBA) {
if (id[2] == 0x20) return "N25Q512A";
if (id[2] == 0x21) return "N25Q00AA";
if (id[1] == 0xBB) {
if (id[2] == 0x22) return "MT25QL02GC";
if (id[0] == 0xBF) {
// SST
if (id[1] == 0x25) {
if (id[2] == 0x02) return "SST25WF010";
if (id[2] == 0x03) return "SST25WF020";
if (id[2] == 0x04) return "SST25WF040";
if (id[2] == 0x41) return "SST25VF016B";
if (id[2] == 0x4A) return "SST25VF032";
if (id[2] == 0x01) return "SST26VF016";
if (id[2] == 0x02) return "SST26VF032";
if (id[2] == 0x43) return "SST26VF064";
return "(unknown chip)";
void print_signature(const unsigned char *data)
Serial.print("data=");
for (unsigned char i=0; i < 8; i++) {
Serial.print(data[i]);
Serial.print(" ");
void create_signature(unsigned long address, unsigned char *data)
data[0] = address >> 24;
data[1] = address >> 16;
data[2] = address >> 8;
data[3] = address;
unsigned long hash = 2166136261ul;
for (unsigned char i=0; i < 4; i++) {
hash ^= data[i];
hash *= 16777619ul;
data[4] = hash;
data[5] = hash >> 8;
data[6] = hash >> 16;
data[7] = hash >> 24;
bool equal_signatures(const unsigned char *data1, const unsigned char *data2)
if (data1[i] != data2[i]) return false;
return true;
bool is_erased(const unsigned char *data, unsigned int len)
while (len > 0) {
if (*data++ != 255) return false;
len = len - 1;
return true;
void printbuf(const void *buf, uint32_t len)
const uint8_t *p = (const uint8_t *)buf;
do {
unsigned char b = *p++;
Serial.print(b >> 4, HEX);
Serial.print(b & 15, HEX);
//Serial.printf("%02X", *p++);
Serial.print(" ");
} while (--len > 0);
