Unable To Compile Teensyduino Included FastLED Library Against 3.1/3.2
I forked mavsky and now I'm trying to compile it against the 3.1/3.2 profile; it fails. My repo with the failing code is here. Any insight? Thanks!
In file included from /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/FastLED/bitswap.h:4:0,
                 from /var/folders/nk/n29krwvj22s9xfk72mk0tt7h0000gn/T/arduino_build_369312/sketch/FrSkySPort.cpp:1:
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/FastLED/FastLED.h:17:21: note: #pragma message: FastLED version 3.001.001
 #    pragma message "FastLED version 3.001.001"
In file included from /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/FastLED/platforms/arm/k20/fastled_arm_k20.h:12:0,
                 from /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/FastLED/platforms.h:12,
                 from /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/FastLED/FastLED.h:52,
                 from /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/FastLED/bitswap.h:4,
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/FastLED/platforms/arm/k20/clockless_block_arm_k20.h: In static member function 'static void InlineBlockClocklessController<LANES, FIRST_PIN, T1, T2, T3, RGB_ORDER, XTRA0, FLIP, WAIT_TIME>::writeBits(uint32_t&, InlineBlockClocklessController<LANES, FIRST_PIN, T1, T2, T3, RGB_ORDER, XTRA0, FLIP, WAIT_TIME>::Lines&, PixelController<RGB_ORDER, LANES, (((1 << LANES) - 1) & ((FIRST_PIN == 2) ? 255 : 4095))>&)':
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/FastLED/platforms/arm/k20/clockless_block_arm_k20.h:88:4: error: 'transpose8' was not declared in this scope
    transpose8<1,2>(b.bytes,b2.bytes);
Using library FastLED at version 3.1.1 in folder: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/FastLED
Using library GCS_MAVLink in folder: /Users/bittondb/Documents/Arduino/libraries/GCS_MAVLink (legacy)
Using library EEPROM at version 2.0 in folder: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/EEPROM
Error compiling for board Teensy 3.2 / 3.1.
