Page 2 of 2 FirstFirst 1 2
Results 26 to 30 of 30
Thread: T_3.6 acting oddly: Program Button doing a reset, no bootloader reprogram
  1. #26
    9,063
    Thought I should chime in
    Does your T_3.6 board have "a very slight curvature "?
  2. #27
    Nov 2016
    10
    I was struggling with something very similar... I found that there was a very very slight warping to my board, and by applying pressure to the edges, I was able to straighten it completely, and when the board is straightened it programs perfectly every time. Might be worth a try?
    Edit:
    Didn't see #26 on the next page... but that is the thread where we figured out what happened with mine.
  3. #28
    https://youtu.be/7RFW-Kr8QA4
    This video clip pretty much shows the issue. Note the program rebooting in the terminal window or the Teesny loading.
    Just pressing the switch or pressing on the processor chip away from the switch reboots, while toward the switch loads. After the video, determined the pencils weren't necessary, but made slightly less pressure required. The most sensitive location on the chip to push was in the
    corner toward the switch and camera.
    This looks like a bad solder joint to me. With ball grid arrays, one intermittent connection means others are likely.
    Last edited by bicycleguy; 12-01-2016 at 07:12 PM. Reason: added about other signals
  4. #29
    Nov 2016
    10
    Virtually the exact same behavior I was dealing with... Pressure on the chip solved the issue.
  5. #30
    Germany NRW
    5,679
    @Paul: Looks like the widely known xbox "ring of death" problem ...
    Perhaps something on the bga-soldering process can be optimized.
