alonsorobots
New member
Hi there!
How do you read the output of sine_fm1?
Below is the code that I made that takes a mic input, finds the note freq, creates sine wave of that frequency, which is then modulated and output to the speakers. It's pretty trippy to hear your voice in pure tone =)
I wanted to be able to print out the output of sine_fm1 that is going into i2s2. i.e if the signal was being modulated by a really slow "triangle", I wanted to be able to print the freq and see it go up and down.
Thanks a bunch!
Alonso
Thanks a bunch!
Alonso
#include <Bounce.h>
#include <SerialFlash.h>
Bounce button0 = Bounce(0, 15);
// GUItool begin automatically generated code
AudioInputI2S i2s1; //xy=101,237
AudioAnalyzePeak peak1;
AudioOutputI2S i2s2; //xy=310,169
AudioSynthWaveform waveform1; //xy=77,30
AudioAnalyzeNoteFrequency notefreq1; //xy=312,291
AudioSynthWaveformSineModulated sine_fm1; //xy=145,102
AudioConnection patchCord1(i2s1, 0, peak1, 0);
AudioConnection patchCord2(i2s1, 0, notefreq1, 0);
AudioConnection patchCord3(waveform1, sine_fm1);
AudioConnection patchCord4(sine_fm1, 0, i2s2, 0);
AudioConnection patchCord5(sine_fm1, 0, i2s2, 1);
AudioControlSGTL5000 sgtl5000_1; //xy=319,350
// GUItool end automatically generated code
AudioMemory(60);
sgtl5000_1.enable();
sgtl5000_1.volume(0.5);
sgtl5000_1.micGain(15);
//this is for button0 and 1
pinMode(0, INPUT_PULLUP);
notefreq1.begin(.40);
waveform1.amplitude(0.0);
waveform1.frequency(60);
waveform1.pulseWidth(0.15);
sine_fm1.frequency(0);
sine_fm1.amplitude(0.75);
elapsedMillis timeout = 0;
uint16_t micTone = 0;
int lastTime = 0;
int waveform_type = WAVEFORM_SINE;
float volPeak = 0;
button0.update();
if (button0.fallingEdge()) {
Serial.print("Control waveform: ");
if (waveform_type == WAVEFORM_SAWTOOTH) {
Serial.println("Sine");
} else if (waveform_type == WAVEFORM_SINE) {
waveform_type = WAVEFORM_SQUARE;
Serial.println("Square");
} else if (waveform_type == WAVEFORM_SQUARE) {
waveform_type = WAVEFORM_TRIANGLE;
Serial.println("Triangle");
} else if (waveform_type == WAVEFORM_TRIANGLE) {
waveform_type = WAVEFORM_SAWTOOTH;
Serial.println("SawTooth");
waveform1.begin(waveform_type);
if (timeout >= 80) {
if (peak1.available()) {
volPeak = peak1.read()*50;
if (notefreq1.available()) {
micTone = notefreq1.read();
//this is useful to remove some noise
if ((micTone > 2000) or (micTone < 70) or (volPeak < 0.05)) {
micTone = 0;
timeout = 0;
micTone = 0;
// knob1 on A3 controls the amplitude of modifier wave that offsets micTone freq
float knob1 = (float)analogRead(A3) / 1023.0;
// knob2 on A2 controls the frequency of modifier wave that offsets micTone freq
float knob2 = (float)analogRead(A2) / 1023.0;
//higher pitch sound louder
sgtl5000_1.volume(mapF(micTone,0,2000,0.5,0.2));
waveform1.amplitude(knob1);
waveform1.frequency(360 * knob2 + 0.25);
sine_fm1.frequency(micTone);
if (micTone != 0 ){
Serial.print("Freq: ");
Serial.print(micTone);
Serial.print(" Amp: ");
Serial.print(knob1);
Serial.print(" Freq: ");
Serial.print(knob2);
if (waveform_type == 0)Serial.print(" Sine ");
if (waveform_type == 1)Serial.print(" Sawtooth ");
if (waveform_type == 2)Serial.print(" Square ");
if (waveform_type == 3)Serial.print(" Triangle ");
if (waveform_type == 5)Serial.print(" Pulse ");
Serial.print(" peak: ");
Serial.print(volPeak);
Serial.print(" |");
for (int cnt=0; cnt<volPeak*100; cnt++) {
Serial.print(">");
float mapF(float x, float in_min, float in_max, float out_min, float out_max)
return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
