Issue:
On some very rare combinations of parts and application
boards, and on a very small percentage of those rare
part/board combinations, sometimes the VDDD
internal regulator does not start up after IC power-up. This can occur
at any VDDIO and VDDA voltage level, and on either the
QFN20 or QFN32 part. The failure is a function of board
design and the slew rates of the power supplies, VDDIO
and VDDA. The failure does not occur if an external regulator is
used to supply VDDD.
Result:
The most noticeable symptom is that no IC
communication/control occurs, and that the I2C bus lines are
held in a low state. Power must be cycled to attempt another
power-up, and to attempt to regain IC communication. Note
that the same applies for SPI communication.
Workarounds:
New Designs
Use an external supply in the system or a separate regulator
to supply VDDD. This VDDD
supply must be between 1.1 V and 2.0
