teensyforu
New member
Hi, I just got Teensy 3.6!!
This is my first playing with electronic so I probably dont know much
I am trying to play around but I have "problem" with teensy.exe
I am using version 1.3 on Windows 7
What I heard is when I connect teensy first time it should blink until you press button.
So I opened up the program and pressed button and nothing happened.
I know it support to change the example picture (one that saying "Press Button on Teensy to manually enter Program Mode) but nothing happen.
I looked drivers and everything seems find. So i just give it try and compile different speed blink and I pressed button and nothing happened. (I also installed teensyduno, had trouble first but figure only support older version of arduino program).
So I turned off completely and restart. Same as before except when I press button it will compile but still on teensy I dont see connection picture as other people are having.
Is it support to act like this or some problem?
-Verbose from Teensy-
19:03:29: remote connection opened
19:03:29: remote cmd: "comment: Teensyduino 1.30 - WINDOWS"
19:03:29: remote cmd: "dir:C:\Users\Main\AppData\Local\Temp\build9eb696f640e1fe156ffd502ca37ddca4.tmp\"
19:03:29: remote cmd: "file:Blink.pde.hex"
19:03:29: File "Blink.pde.hex". 20636 bytes, 2% used
19:03:29: remote cmd: "status"
19:03:29: status data sent
19:03:29: remote connection closed
19:03:58: Device came online, code_size = 1048576
19:03:58: Board is: Teensy 3.6 (MK66FX1M0), version 1.03
19:03:58: File "Blink.pde.hex". 20636 bytes, 2% used
19:03:58: set background IMG_ONLINE
19:03:58: elf size appears to be 1048576
19:03:58: elf binary data matches hex file
19:03:58: Code size from .elf file = 1048576
19:03:58: begin operation
19:03:58: flash, block=0, bs=1024, auto=1
19:03:58: flash, block=1, bs=1024, auto=1
19:03:58: flash, block=2, bs=1024, auto=1
19:03:58: flash, block=3, bs=1024, auto=1
19:03:58: HID/win32: waiting for device
19:03:59: HID/win32: waiting for device
19:03:59: flash, block=4, bs=1024, auto=1
19:03:59: flash, block=5, bs=1024, auto=1
19:03:59: flash, block=6, bs=1024, auto=1
19:03:59: flash, block=7, bs=1024, auto=1
19:03:59: flash, block=8, bs=1024, auto=1
19:03:59: flash, block=9, bs=1024, auto=1
19:03:59: flash, block=10, bs=1024, auto=1
19:03:59: flash, block=11, bs=1024, auto=1
19:03:59: flash, block=12, bs=1024, auto=1
19:03:59: flash, block=13, bs=1024, auto=1
19:03:59: flash, block=14, bs=1024, auto=1
19:03:59: flash, block=15, bs=1024, auto=1
19:03:59: flash, block=16, bs=1024, auto=1
19:03:59: flash, block=17, bs=1024, auto=1
19:03:59: flash, block=18, bs=1024, auto=1
19:03:59: flash, block=19, bs=1024, auto=1
19:03:59: flash, block=20, bs=1024, auto=1
19:03:59: sending reboot
19:03:59: begin wait_until_offline
19:03:59: offline, waited 4
19:03:59: end operation
19:03:59: set background IMG_REBOOT_OK
19:03:59: redraw timer set, image 14 to show for 1200 ms
19:04:00: redraw, image 9
19:11:52: Device came online, code_size = 1048576
19:11:52: Board is: Teensy 3.6 (MK66FX1M0), version 1.03
19:11:52: File "Blink.pde.hex". 20636 bytes, 2% used
19:11:52: set background IMG_ONLINE
19:11:52: elf size appears to be 1048576
19:11:52: elf binary data matches hex file
19:11:52: Code size from .elf file = 1048576
19:11:52: begin operation
19:11:52: flash, block=0, bs=1024, auto=1
19:11:52: flash, block=1, bs=1024, auto=1
19:11:52: flash, block=2, bs=1024, auto=1
19:11:52: flash, block=3, bs=1024, auto=1
19:11:52: HID/win32: waiting for device
19:11:52: flash, block=4, bs=1024, auto=1
19:11:52: flash, block=5, bs=1024, auto=1
19:11:52: flash, block=6, bs=1024, auto=1
19:11:52: flash, block=7, bs=1024, auto=1
19:11:52: flash, block=8, bs=1024, auto=1
19:11:52: flash, block=9, bs=1024, auto=1
19:11:52: flash, block=10, bs=1024, auto=1
19:11:52: flash, block=11, bs=1024, auto=1
19:11:52: flash, block=12, bs=1024, auto=1
19:11:52: flash, block=13, bs=1024, auto=1
19:11:52: flash, block=14, bs=1024, auto=1
19:11:52: flash, block=15, bs=1024, auto=1
19:11:52: flash, block=16, bs=1024, auto=1
19:11:52: flash, block=17, bs=1024, auto=1
19:11:52: flash, block=18, bs=1024, auto=1
19:11:52: flash, block=19, bs=1024, auto=1
19:11:52: flash, block=20, bs=1024, auto=1
19:11:52: sending reboot
19:11:52: begin wait_until_offline
19:11:52: offline, waited 4
19:11:52: end operation
19:11:52: set background IMG_REBOOT_OK
19:11:52: redraw timer set, image 14 to show for 1200 ms
19:11:54: redraw, image 9
